Subframe + RTAB OEM rubber installation with vise
  • BaltimoreBimmer
    • Apr 2016
    • 307
    Will Be installing OEM bushes this week. Is it ok to utilize librication on the rubber subframe and trailing arms bushings? Also, I haven't seen it mentioned too much, and will recheck the Bentley, but figured I'd ask: do I have to preload either the subframe or trailing arm bushings?
    I have a standard bench vise which people (sketchily) have reported makes installation a breeze. I say sketchily b/c not many people have shown pictures of this actually working, only talk about future uses.
  • redlightpete
    • Mar 2012
    • 265
    You can press the subframe bushings in with a bench vise, but it should be a sturdy one. If your vise weighs less than 20 lbs, it might be dodgy. For the trailing arm bushings I use a long threaded rod and some sockets to remove and install them.
    You'll need to lubricate the bushings before installation. People may say this is crazy, but WD-40 works well. It is a good lubricant and then dries to a sticky film that will prevent the bushing from moving. Try it for installing bicycle or motorcycle grips if you don't believe me.
    The trailing arm bushing bolts should be tightened with the arm in its normal loaded position. The bushing deflects to allow movement of the suspension, so that deflection is minimized by setting it in its nominal operating position before you lock the inner sleeve in place. I'd be surprised if the Bentley manual does not mention this. Hope this advice isn't too late for you.
    • jeffnhiscars
      • Jun 2011
      • 6011
      it's always best to use a water based lube on anything rubber. i've had the same $8 bottle of cable pulling lube i got from home depot for years. perfect for CABs as well
      Alice the Time Capsule
      • BaltimoreBimmer
        • Apr 2016
        • 307
        Believe it or not, the Bentley mentions nothing about tightening under load. Advice is not too late, putzing around waiting on parts still.
        Just pushed in the TA bushings with the vice. Used a dab of dawn to help ease it in. Also used a socket on one side to allow the inner end to slightly poop out. After getting them in I decided i will be sending the subframe to my local mechanic to push in. I don't want to deal with that lol. But perhaps I do. We will see
        Here some pics for your time:
