Help! Rear subframe bolts stripped to the frame
  • Staszek
    • 2533
    I have 3 more bolts left to drop my rear subframe. I was feeling good, almost there then bam they 3 of the 4 bolts are stripped just enough to slip. I stopped so I didnt make it any worse, but I am stuck here.
    Options?
  • Northern
    I like cupcakes & sh!tboxes
    • 5259
    drill them out. Once the plate is off, you can remove what's left with some vise grips.
    Digging all the schutz out of those hex holes usually seems to help them not strip.
    Originally posted by priapism
    Originally posted by shameson
    • kronus
      • Apr 2008
      • 13032
      other options - angle grind the heads off, hammer a torx into 'em
      those bolts suck and commonly get frozen in place
      cars beep boop
      • Staszek
        • 2533
        Thanks, the first one came out so easy, the next three I knew they were bad the second I tried to turn it.
        • noid
          • 1537
          You can probably get a bolt extractor around them or drill them out.
          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
          Your resource to tools and tips: www.rtstools.com
          • CB-M3
            • Jun 2011
            • 348
            yeah all options listed should work.
            1) Take angle grinder to the head.
            2) Pound on bolt extractor socket.
            3) Drill it out.
            • Staszek
              • 2533
              3) Drill it out.
              Just bought some bolt extractor sockets, lets see if those work.
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                I cut them them off with an angle grinder
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • Staszek
                  • 2533
                  Got them out. One came out normally. One I was able to get out with a bolt extractor. One I was able to break off the head with the bolt extractor and knock it out. Last one I had to drill all the way through.
                  At least its done and the subframe is out.
