Best lube for rtabs
  • Lenwood
    • Mar 2012
    • 100
    Best lube for rtabs
    What is the best grease or lubricant to use with the rear trailing arm bushings?
    1989 325ix(sold)
    1989 325i sedan s52 powa (current)
  • uturn
    • Dec 2010
    • 1001
    I used the copper based lube that came with my poly bushings. Looks similar to the loctite anti-seize copper lube #38650
    • jeffnhiscars
      • Jun 2011
      • 6010
      I don't see where you specify what bushings you are using. Stock rubber only gets a water based lube to ease installation and settling before it dries.
      Alice the Time Capsule
      • Lenwood
        • Mar 2012
        • 100
        Re lube
        Going with the green polyurethane type
        1989 325ix(sold)
        • AndrewBird
          The Mad Scientist
          • 11898
          Silicone grease of any type. Other greases can deteriorate the poly.
