Weak Brakes!!
  • ForcedFirebird
    • Feb 2007
    • 8300
    Again, my prices reflect a delivery within hours, so not comparable to a mail order. :/
    Are you handy enough to reman your own M/C? The parts are seriously $20.
    If not, me, personally, would choose the ATE over all others for QC.
    john@m20guru.com
    Links:
    • gespinal0301
      • Jan 2011
      • 317
      I've been watching videos of rebuilds on the MC and honestly it doesn't look too bad. It's basically a snap ring and a bunch of seals. The issue is I can't find a rebuild kit on any of the regular websites I buy parts from. If you can point me in the right direction it would definitely be appreciated! If not I'll just go with the e32 MC upgrade.
      If this doesn't solve the problem I guess my only other thought would be brake booster or the check valve.
      My Daily Driven 318is
      • ForcedFirebird
        • Feb 2007
        • 8300
        34311154861 NLA :(
        There's a vendor on eBay that has them NOS, but he is asking $50...
        https://www.ebay.com/itm/BMW-E30-325...-/302316016137
        john@m20guru.com
        Links:
        • gespinal0301
          • Jan 2011
          • 317
          Yeah I saw that too, looks like I'm going with the e32 brake master! Can anyone verify this is the right PN: 34311156643?
          • Todd Black 88
            • Oct 2007
            • 3449
            I had an issue with the cv on the vacuum line to the booster that cause me all sorts of head aches.
            I would try that first, as it’s cheap and yours is most likely 30 yrs old
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • ForcedFirebird
              • Feb 2007
              • 8300
              Yup. Just used on on an s54 swap.
              john@m20guru.com
              Links:
              • gespinal0301
                • Jan 2011
                • 317
                Would any generic fit?
                I'm going to change the check valve and see if that fixes up anything first before I spend $$$
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  I would assume so, but the factory one was quite cheap iirc.
                  Also, make sure there is no leaks on the line and fittings to the cv.
                  2010 F650gs twin
                  • gespinal0301
                    • Jan 2011
                    • 317
                    Originally posted by Miguel801
                    I have same pads and I noticed like a good percentage more stopping power that starts poorer than oem until like a simple couple stops from 40 to warm them up then they are very noticeably better, especially in the high speeds. also maybe smoke test the brake booster?
                    Forgot to reply to this, but how do you perform a smoke test?? lol
                    • gespinal0301
                      • Jan 2011
                      • 317
                      I changed everything to silicone hoses when i did the mess under the intake (M42 stuff).
                      I checked and couldn't find a part number from fcp, pelican or turner. Autozone only pulls up GM stuff and they look smaller than what I have
                      • gespinal0301
                        • Jan 2011
                        • 317
                        Just a quick update, I bled my brakes again and the fluid was pretty dirty considering the fact that they were bled 4-6 months ago.
                        My brakes did get better, but they still aren't where they should be. Once i get back home I'm going to follow Jon's advice and clear the hard lines. I'll probably replace the booster and master as well just cause since they're old and itll be a nice upgrade.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          ...it's joHn, but all the same :p
                          If you still have crud in them, keep bleeding until the fluid is clear.
                          Rubber bits compress far more than real hydraulic fluid ;)
                          john@m20guru.com
                          Links:
                          • gespinal0301
                            • Jan 2011
                            • 317
                            My brakes did get better, but they still aren't where they should be. Once i get back home I'm going to follow JoHn's advice and clear the hard lines. I'll probably replace the booster and master as well just cause since they're old and itll be a nice upgrade.
                            Fixed just for you ;)
                            Im going to let it sit for a week and rebleed again
                            • cheffy30
                              • Sep 2016
                              • 1159
                              Where did you get your master cylinder from? And would it be worth it to upgrade to the e32 MC?
                              my buddy here, spiDmang got a new oem. i am not sure about the e32 MC.
                              '90 325i sedan daily driven
                              '85 325e coupe also a daily
                              • rturbo 930
                                • Dec 2005
                                • 2628
                                I wonder if this is my problem, too. I stepped on the brakes a bit harder than usual the other day, and at a certain point, they basically just gave, and went to the floor. Not like a 100% brake loss, but still very noticeable. I pumped em a bit to see what was up, and to see if pedal pressure would come back. It did. It seems like a bad seal could be the issue, when more than X amount of pressure is applied to the seal, it gives.
                                Thoughts?
