I am at that critical point right now of my rear subframe removal. I have gotten every thing out and took out the 22mm nut holding the bushings in place. My questions are: Do these bolts need to come out? If they do, how? Also there looks to be a washer on the top of the bushing, touching the bottom of the body where the posts go through. The washer is part of the pin that goes through the body so this should come out also? I have been pounding on the pins from the top with the rear seat out with a 14mm socket and a hammer. Looks to be doing something, but not that great. Am I doing this right or is there something that I should be doing differently? Maybe a bigger hammer? I am using a dead blow right now.
Thanks.
Thanks.
