E30 x-brace: does it exist?
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    is there such thing as an e30 x-brace, like those commonly sold for e36's? I heard once that they came on the cabrios, but i have also heard there is no such thing. If they are out there, i thought it might be a good way to help stiffen up the chassis.
  • SchnellerVert
    • Sep 2005
    • 3948
    Yeah use the E36 parts and fab it in.
    • broke30
      • May 2007
      • 1019
      Does it require drilling?
      Max
      • PiercedE30
        • Apr 2005
        • 4220
        Max
        Seriously?
        Yes, it does. It also requires a fudge factor since you are making newer E36 parts fit on an older E30.
        My 2.9L Build!
        • LINUS
          • 2422
          For all the work the x-brace is, wouldn't it be a lot easier just to tack-weld your front subframe in spots easy to cut with a die grinder if you need to pull it for work?
          It's not how you handle the good times, but the faith you keep in the bad that defines you.
          • Cooper
            • Jan 2007
            • 99
            Max
            lmfao
            • amdspitfire
              • Mar 2006
              • 254
              xbrace will protect your oil pan and allow you to easily unbolt it if you need to
              • PiercedE30
                • Apr 2005
                • 4220
                but an E36 x-brace doesn't go under the oil pan in an E30. E30 oil pans are in front of the subframe.
                My 2.9L Build!
                • george graves
                  • 20003
                  I think jordan did this - but he was ultra quite about it...
                  Originally posted by Matt-B
                  • Jand3rson
                    • 37587
                    Yup, he did. E36 M3 x brace installed on his car, I think he just had to drill a couple new holes.
                    • george graves
                      • 20003
                      If memory serves, it was a tight fit, took some trimming and a few holes drilled in the floor pan/tranny hump.
                      BTW - I get really annoyed when people call it (pronounce it) a "X-brace" like it some f-ing starwars product...It's Called a "Cross-brace"...
                      Shorthand for typing a description is "x-brace" to make room.
                      I can spot a newbi a mile away when they ask about the "x"-brace...
                      So X-brace in an email = good - calling it a "X-brace" out loud = bad...
                      Questions? HTH..
                      Good...move on..
                      • M3TROY
                        • Apr 2006
                        • 578
                        yea their was someone who made an X-brace for a vert a while back but cant remember who it was......... driving me nuts now cauzz i want one for mine.
                        i think they just took a stock one and drilled some new mounting holes.
                        think ill try it myself cauzz their cheap N way.
                        • CorvallisBMW
                          • 13039
                          I was thinking about doing the same thing...why not? worse case is I loose the $20 it cost to get it from the wreckers.
                          • NC325iC
                            • Mar 2004
                            • 6565
                            anyone done subframe connectors?
                            lol i saw that on POWERBLOCK RAAHHHH!!!
                            • HST
                              • Jan 2006
                              • 757
                              You mean like fab up something to connect the front and rear sub-frame together?
                              Originally posted by KingB
                              Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
