Just a thought on new rear brake design...
  • bwh13
    • Jan 2007
    • 437
    Being that I'm always looking to something completely different (and most of the time just plain expensive) I'm thinking of re-engineering the rear brakes on the E30.
    Since I want to install a bigger rear brake to balance out the fronts that I'm putting on (11.75" 4 piston kit), I started thinking of ways to reduce the unsprung weight on the rear.
    While I can do it by making a rotor with the park brake drum as part of the hat, the aluminum hats and calipers will reduce the weight by 6-8 lbs per side compared to the stock components, but I then thought, why not eliminate the unsprung weight altogether?
    How you ask? By moving the rotor/caliper assembly to the end of the differential output/axle flanges, like the old Jaguar XKE. This would allow the use of just the drum portion of the existing rear rotor, by machining off the friction surface of the existing rotor.
    Then I could design a carrier to mount the caliper off the differential and have the rotor on the axle flange/axle.
    Of course this is in the 'what if?' stage, but it sure seems like a trick way of solving the problem, so I'll just have to get out the extra diff and see what I can do with it...
    and please no posts on 'why change the brakes, they're good enough', they are NOT good enough for me :)
  • NC325iC
    • Mar 2004
    • 6565
    clearance i think might be an issue
    • AndrewBird
      The Mad Scientist
      • 11898
      So wait, you are saying use JUST the parking brake drum setup for the rear braking? Or are you saying to just move the parking brake to the diff, leaving the stock setup.
      • 2002maniac
        • 4260
        read it again
        • 2002maniac
          • 4260
          This would put alot of stress and heat on the CV joints. You'd probably want to set up a diff cooler too.
          and it would be alot of work.
          Stock brakes are fine :)
          • matt
            • 3732
            I don't think the halfshafts can handle it.
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Stop.... If you have not done a Jag rear brake job, then you don't grasp what a pain in the dick it is. Why make repairs that much harder? Just buy Massive BBK, and be done with it.
              I mean, Instead of using the door designed, why tear down the barn to get the cow out?
              • direction88
                • Feb 2007
                • 228
                This thread reminded me of this car and its amazing rear end and breaks.
                Good luck looks like quite the job!
                "Drifting an E30 is like pouring out a beer just to get a nickel for the can"
                • moatilliatta
                  • 6158
                  same thing i was thinking. i want to do the same
                  @Zakspeed_US
                  • SamE30e
                    • Sep 2007
                    • 4319
                    I don't think its worth it in the end. Massive BBK call it a day.
                    1985 325e 2.8 Turbo VEMS
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      That's one fukin redonkulous display of insanity in brake/rear end desing. I would have to say thats 10x anything an BMW powered e30 could ever need.
                      • e30 gangsta
                        • 3877
                        massive bbk save the time and the $
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          Originally posted by 2002maniac
                          read it again
                          I'm still a little confused. You want to move the stock brake system to the diff, minus the parking brake, then leave the parking brake where it is, minus the rotor surfaces and the caliper?
                          • ColdAccord
                            • 5926
                            lol inboard brakes on an e30
                            Originally posted by blunt
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              It's uber fuh raze.
