AKG poly subframe and RTABs?
  • gearheadE30
    • Jun 2007
    • 3734
    My car is getting a bit scary on the highway because the rear bushings are so far gone. I have offset poly CABs from AKG now, and it is a bit squeaky but not too bad. Will the rears be just as bad? How hard is it to install all this, not including the job of getting the subframe out?
    Project M42 Turbo
  • bats
    • Jan 2008
    • 128
    Did you lube the cabs? Which type did you go for? I bought 75D for the subframe and rtabs.
    I'm just waiting for a good day to pull the subframe and do them off the car.
    • gearheadE30
      • Jun 2007
      • 3734
      Yeah, I have the 75Ds and they are lubed, but they still squeak quite a bit. Its eally more of a clicking noise.
      Project M42 Turbo
      • DSP74
        • Nov 2007
        • 1121
        Lube poly bushings with the silver anti-sieze lube to eliminate squeeks.....Lasts a LONG time.....Just try not to get it on you it's hard to clean up.
        88 325is
        • gearheadE30
          • Jun 2007
          • 3734
          hmmm havn't heard that one before. Is there a difference between the silver stuff and the copper-colored stuff?
          Project M42 Turbo
          • makaio
            • Nov 2007
            • 135
            My powerflex subframe and trailing arm bushings don't queak a bit. Now the IE sway links they clunk like a busted up old pinto though.
            • dvmotorsports
              • Apr 2008
              • 658
              i just recently did mine. the rears will squeak, but how much, i dunno. mine is still in "roller" stage and i can hear them. if you yank the subframe, the job is no problem. takes an afternoon or less. while you are in there, might as well do the subframe bushings as well.
              Originally posted by jrhaile
              For the record I have never fucked a goat.
              • gearheadE30
                • Jun 2007
                • 3734
                Makaio-yeah, that would be why I'm not going to use IE bushings :)
                dvmotorsports-there is not question about not doing the subframe bushings. At this point I'd say they are becoming a saftey problem they are so bad.
                Project M42 Turbo
                • Sam Cogley
                  • Jun 2008
                  • 521
                  On other vehicles, I've always used the super-sticky silicone grease that Energy Suspension sells for their poly bushings. Never have had a squeak.
                  • e30lyf
                    • May 2007
                    • 4552
                    i have IE bushing for less than a month. i never heard they squeak even once. as far as i know they squeak when it's cold season.
                    - Fercy -
                    Classic BMW Specialists
                    Santa Clarita, CA
                    www.BimmerHeads.com
                    • brickwhite
                      • 582
                      I have the AKG in the rear..... squeak squeak
                      All,
                      I regret putting the Poly Subframe and TA bushings in. The 91 Cabrio squeaks all the time. I am really thinking about buying rubber and changing them out.
                      Brick
                      • E30_fiend
                        • Apr 2006
                        • 7348
                        There really isn't a difference between copper and aluminum stuff. I've just heard that the copper stuff lasts a lot longer. That's what I used and they still squeak but its tolerable. The install isn't very hard but make sure you use a shit load of the copper or aluminum stuff. Don't be alarmed when they squeak because with as much movement as there is back there, its inevitable.
                        Do the subframe bushings as well while you're in there.
                        Taylor
                          • 34844
                          I don't know how you guys are getting squeaking in the rear. it shouldn't even be rotating on the bushing - that's what the metal insert is for.
                          5 years on poly TA and subframe bushings and they've never squeaked.. of course poly doesn't hold up all that well, I know everyone says it lasts longer than rubber, but it just isn't true. Poly tends to deform over time, and my bushings are due for a 2nd refresh now. I have AKG waiting to go in next.
                          • Aptyp
                            • 6584
                            Had IE TABs on my last car and they didn't squeak at all, I also had their subframe mounts.
                            My ie sway bars clunked when the mounting tab broke off from the trailing arm. Had to replace it. And no more noises.
                            Not everything IE is bad. Some stuff are the exact same stuff you'd buy anywhere else.
                              • 34844
                              like ebay or the streets of Beijing? ;)
