So my brakes have never been great so I decided to treat myself to some new Hawk pads, Zimmy rotors and some stainless lines from TMS. It was better, but still not great and now when I push it hard, I'd start boiling fluid. Upgrade to Super Blue and so far no boilage but there's still a distinct lack of brakey-ness unless you have a lot of weight on the pedal. After having my boss drive it we're starting to suspect the ABS pump, especially because the pedal takes a lot of force to press down, even with the bleeder nipples open on the calipers. I would suspect one of my new lines but the force needed to compress the pedal is consistent no matter which caliper is open.
ABS pumps are prohibitively expensive these days so I'd rather just delete it all before spending money that could go into paying off debts and larger brakes and such.
Has anyone had a similar issue with your brakes, feeling like there was some sort of restriction pretty far up in your system and if so, was it indeed the ABS pump?
Thanks!
Brendan
Thanks!
Brendan
