Front brakes to rear
  • Gus
    • Jan 2004
    • 285
    just wondering if anyone has done/researched this...ive got some big brakes for the front but with those on i imagine it will upset the balance...moving the fronts to the back would help....any thoughts? of course i would need a bigger MC
    JUNGL3
    1990 "333i" Sport
    • 34844
    you can't just stick the front rotors and calipers back there.. they are completely different. there are BBK that come with front and rear, the IE kit comes to mind.
    besides, the rear rotors are the same diameter as the front anyway.. the fronts just have more surface area.
    • Gus
      • Jan 2004
      • 285
      i know the front and rear rotors are diff.....the rears have a drum....if it fitted i could do without a handbrake, and if it doesnt i could use the rear disc anyway....another reason i wanted is that the fronts are vented....i also realise the front calipers are different....was thinking to make a bracket of some description so they would fit
      JUNGL3
      1990 "333i" Sport
      • 808BMW
        • 2910
        I'm guessing drums out back for gus
        • Gus
          • Jan 2004
          • 285
          sorry...i meant the handbrake drum...got rear discs! thank god
          JUNGL3
          1990 "333i" Sport
          • Gus
            • Jan 2004
            • 285
            anyone?
            JUNGL3
            1990 "333i" Sport
            • Jon '92 325ic
              • 172
              Wilwood makes a brake bias valve
              Wilwood makes a brake bias valve. Ireland Engineering sells it for $52. "The valve allows reduction of pressure to balance the braking of cars with too much rear brake." (according to the website). Maybe call Ireland and ask them if the valve can be used to move balance from a car with too much front brake. Or if there's another valve for that. Just a suggestion. I don't have first hand experience with this type of issue.
              This product is listed on wilwoods website:
              • Ryan Stewart
                I Love Miatas
                • 8978
                Most people just stick with a moderate BBK up front and call it good. There is enough trailbraking ability on the stock system, just get some good low-fade pads.
                If you do a whole kit you have to run a bias valve because the back will lockup all the time. There just isnt enough weight back there under braking.
                I would only upgrade the back if there was a whole kit designed to fit under 16" wheels. For the IE kit you need 17" wheels.
                Im now E30less.
                • BahnE30
                  • 1050
                  gus, don't you have bottle caps???
                  BBK won't fit under them stock brakes barley do!! FFT
                  • Gus
                    • Jan 2004
                    • 285
                    yeah i got bottle caps at the mo...sold my 17's a while ago....the evo brakes for the front barely fit under a 16" wheel.....depends on the wheel....a brake bias valve is a good idea...however i hear they are illegal for the street? and expensive? im just wondering if the fronts DO fit on the rear...i dont even need big brakes now! i might give it a dummy run next time i bleed brakes...just for a laugh. having said this i imagine the stock brakes would be more than sufficient on the back....hmmm i like the idea of a valve...thanks
                    JUNGL3
                    1990 "333i" Sport
