stainless brake lines
  • cbouchez
    • May 2007
    • 2789
    I need to do a brake job on my e30 es
    I'll be replacing front and rear rotors with Brembo blanks
    Pads Hawk HP+
    ATE Super Blue Fluid
    I would like to replace the brake lines with the stainless lines while I'm doing the job. Any input? I know it will probably make a difference but where is a good place to get them.
    Are they all the same 325is or I with the E models?
    Follow my IG @bouchezphotography
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    turnermotorsport.com or bimmerworld.com, they sell 6 line kits and they're dot approved
    • cbouchez
      • May 2007
      • 2789
      cool thanks man!
        • 34839
        the UUC lines are also very nice and come in a set of 6
        beware of cheap ebay 4 line crap
        • z31maniac
          • 17566
          nando, who makes the clutch line? UUC?
          www.gutenparts.com
            • 34839
            they sell one, I don't know as I have the stock rubber line. I have the 6 line brake kit though which is way nicer than my old IE set.
            • smonkbmw
              Professor
              • Jun 2006
              • 4549
              look on ebay uk christian. they have Goodridge kits over there still. like these: http://cgi.ebay.co.uk/GOODRIDGE-BRAK...3A1|240%3A1318
              supposed to be the best around.
              • tonytony
                Knee deep in poopie
                • Jan 2004
                • 3498
                uuc makes one yes, and so does blueapplesoda on this board, i have one of his
                • einstein57
                  • Jun 2007
                  • 10780
                  +1 for blueapplesoda
                  www.gecoils.com
                  • e30lyf
                    • May 2007
                    • 4552
                    +10 i have these on my car no complaint.
                    - Fercy -
                    Classic BMW Specialists
                    Santa Clarita, CA
                    www.BimmerHeads.com
                    • Kingb
                      • 928
                      I just got a set of UUC's waiting to install though. They were a priced good compared to the rest and DOT
                      Originally posted by Nicademus
                      My car beats off to that car. :bow:
                      • cbouchez
                        • May 2007
                        • 2789
                        thanks guys I'll have to look at the UUC lines.
                        • cbouchez
                          • May 2007
                          • 2789
                          E30 VS E36 brake lines.
                          I have been searching for a set of stainless brake lines and I found out that in the UUC site doesn’t give you an option between the e30 and the e36 325
                          I have a set of stainless brake lines brand new from my e36 that I would love to use $$ that I would save.
                          Technical features:
                          fully compliant with DOT Standards (MVSS-1006)
                          lines burst-tested to 6000psi
                          (maximum tested pressure from a BMW braking system is 1200psi)
                          TeflonĀ® inner line covered with a woven layer of stainless steel
                          and covered in an abrasion-resistant material (translucent blue plastic covering).
                          plastic end pieces protect assembly, no exposed steel fibers to stick fingers.
                          applications and pricing:
                          $119 6-line kits fit:
                          3-series 1992-1999 E36 - M3, 328, 325, 318 (not ti)
                          3-series 1987-1992 E30 - 325, 318
                          M5 1988
                          Any of you guys have done this?
                          • DrewC
                            • Nov 2008
                            • 61
                            I got a set off eBay, what's wrong with them? I'm installing them right now, and they look fine to me.
                            1986 325ES LeMons Racer
                            • JJe30
                              • 2044
                              A lot of the ebay kits I've seen were only 4 lines.
