stainless brake lines
  • asubimmer
    • 6482
    Korman Autoworks sells a 6 line kit and it is the cheapest out of the big brands iirc
    • DrewC
      • Nov 2008
      • 61
      Originally posted by JJe30
      A lot of the ebay kits I've seen were only 4 lines.
      Mine came with 6 but where do the other 2 go? I only saw hard steel lines besides the 4 rubbers.
      1986 325ES LeMons Racer
      • tonytony
        Knee deep in poopie
        • Jan 2004
        • 3498
        look harder near the rear subframe you'll see it
        • SpecM
          • Oct 2005
          • 4531
          the other two are tucked up above the rear subframe, they are easier to see from underneith
          1989 cirrisblau-metallic 325i
          • DrewC
            • Nov 2008
            • 61
            Found them. I hadn't ventured my way to the rear yet, was just going off what my dad had said. Thanks, glad to catch that before putting everything all back together. We have the car up on stands on all 4 corners while we overhaul the beast. :D
            • jtb_29
              • Oct 2006
              • 273
              That's gotta be a first for Korman...
              The grilles really distract you from the fact that someone took a sledgehammer to the front end.
              • T Verdier
                • Aug 2007
                • 2636
                This was a very helpful thread. Was uuc dot approved? Does it realy make a difference?
                • norcalE30
                  • Dec 2008
                  • 932
                  if something happens to your brakes and you hit something/someone and they find out your lines werent DOT approved its all your fault
                  otherwise, i think its no prob
                  Originally posted by kronus
                  pff, all of you are slow as hell anyway. Eta > all
                    • 34844
                    they aren't going to check, unless you kill somebody, and even then, unlikely.
                    besides, most of the time if you hit somebody else's car its your fault regardless.
                    FWIW, UUC is DOT approved. They are really nice lines. My original IEs lasted 6 years without problems (not DOT approved) but I think the UUCs will last longer.
