D,
I had an awful feeling you put the offset in the bracket incorrectly. : (
The brackets should be completely flat. The 1mm of offset should only be in the radial plane. Your brackets (unfortunately) have 1mm of offset in the axial plane.
So, there's good news and bad news. You can salvage your brackets by simply having them machined flat to 13mm.
Great job on the bracket design! Your numbers are VERY close to mine. You could land a f**king jumbo jet with those damn things! : )
With the bracket machined flat, you can use steel shim washers to get the caliper perfectly centered to the rotor. (FYI - Brembo racing calipers use shims for precise caliper positioning)
Since the RX7 rotor is the same thickness as the Corrado rotor (22mm) you should not have any problems once the calipers are shimmed. Make sure you use same number of shims between both mounting bolts, to keep the caliper square and to avoid any binding problems with caliper mounting.
You're on the right track....keep at it.
