Massive BBK Wheel Fitment Guide
No not running BBK yet, all stock brakes. Been eyeing these MASSIVE kits for a long time but haven't pulled the triggersigpicComment
massivebrakes.com
Count yourself lucky if you ca fit something else than stock calipers under these wheels.
As far as I know, the 280x22mm Street kit will fit. That's it. The VW Corrado rotor is offset more inward than the e30 rotor, and the caliper is narrow.
Available in two configurations. VW Corrado G60 rotors, or two-piece rotors with alu hats
What else is available for our e30?
The kit with an AP Racing caliper is a 300x32mm kit. No way it fits under your wheels. and it is very expensive as calipers only will cost you $1200.00usd for the set ;-)
Last edited by Massive Lee; 03-28-2017, 01:49 PM.Brake harder. Go faster. No shit.
massivebrakes.com
If anyone is wondering
XXR 531 - 16x8 ET20 require a minimum 10mm spacer (12mm would be a safer option) using the Massive BBK 300x32mm Race Kit. No issues in the rear.Alpine White 1989 E30 Coupe - LS1/T56Comment
massivebrakes.com
For autocrossing, you don't need more than the Street kit. It will be a great improvement over stock. Less play in the caliper. Better modulation and cheap brake pads.Brake harder. Go faster. No shit.
massivebrakes.com
Only within the 300x32 Race configuration. At $600.00usd a pop, you want to put these clampers to a good use. ;-)
BTW $600.00usd is what the AP Racing importer Essex, in North Carolina, charges. You can probably get them for cheaper from a distributor. These calipers were much cheaper initially, then suddenly the price hit the roof...
If anyone was able to get them for cheaper, let us know. ;-)Brake harder. Go faster. No shit.
massivebrakes.com
