issue with brand new braided stailess brake line( pictures)
  • Iloveboost
    • Sep 2019
    • 136
    Hi !
    I was in the process of install my brand new braided brake line but i thing i might have an issue with it.
    i bought my stainless line on the web at : autohausaz.com.
    they dont seem to be branded ...
    to problem is that the fitting that goes on the caliper is not Bubble flare. i have install the line from the hardline to the trailing arm with no issue at all. but now the braided line frome the trailing arm to the caliper seem to have the wrong fitting type.
    ( it is the same for the front caliper..)
    i got you 2 pictures to compare the old hose that were on the car ( dont know if it oem , but it is what i remove )
    i have made some research here and there and some say ishould not install them , and other have been in the same struggle and they install them without any issue..
    i have write to autohauaz with no anwser at the moment.
    please could you clear me up with this ?
    thanks
  • Vincenze
    • Apr 2019
    • 1046
    The original hose better matches the shape of the bottom of the hole for the hose in the brakes.
    • Iloveboost
      • Sep 2019
      • 136
      I know that ... that why i asking ..
      • roguetoaster
        Biggus Tippus
        • 7830
        It will probably work once bottomed in to the caliper, but you run the risk of stripping threads if too much force is applied to compensate for the mismatch in seat profile. As an aside, all of the stainless lines I've seen before matched, or were pretty close to, the original flare type, so you might just have the wrong part.
        • Vincenze
          • Apr 2019
          • 1046
          BMW brake line flares explained: why E30s use bubble flares, not double flares - unions, materials and how to flare correctly.
          Bubble flare in E30.
          Japanese flare.
          • Northern
            I like cupcakes & sh!tboxes
            • 5288
            Definitely the wrong part, or their manufacturer fucked up.
            Originally posted by priapism
            Originally posted by shameson
            • Mpolito3355
              • Mar 2018
              • 82
              Originally posted by Vincenze
              http://www.rtsauto.com/brake-lines-f...-double-flare/
              Japanese flare.
              Wow learn something new every day! Thank you for today's lesson
              PERSON 1 - "It whispers to me at night...and convinces me i have to spend all my earnings on it...and buy all this stuff....to be cool...and be euro."
              PERSON 2 - "Oh your married too?? Oh you mean the car....yes ....yes i agree...:shock:"
              • Iloveboost
                • Sep 2019
                • 136
                So far so good ....
                i have install the and bleed de brake and test Drive with hard braking ( bellow 50mph) and everything home on , no leak ..
                what will you doing with this situation ??...
