Ground Control not sittin low in the front??
  • e30this
    • 3580
    Ok So I finshed my suspension this weekend and when I say the car down I realized that front is not even as low as my IE3's...
    When they are turned all the way down I have maybe at most 1.5 inches of shock travel. I put the perches 3.5 inches down the tube compared to the 2.5 that GC says to do.
    My setup in the front is IE street and track camber plates, bilie sports and ground control 6 inch 500lb springs.
    This is all the lower that it sits.
    Here is another shitty photo but a little better angle.
    Anyone have any suggestions?? From the ground to the lip of my fender is is 23 1/2 inches or so.
  • optimusp517
    • Oct 2005
    • 797
    thats weird heres what mine looks like when i had them
    • e30this
      • 3580
      is that dumped all the way down?? How tall is your wheel and tire combo?
      • sticksdaman
        • Apr 2005
        • 2987
        [quote=optimusp517;1501997]thats weird heres what mine looks like when i had them[\quote]
        Were you also running bilstein sports?
        Originally posted by ebelements
        Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
        • e30this
          • 3580
          ^^^ Wut he said. :)
            • 34847
            Aren't IE camber plates notorious for adding lots of stack height?
            • e30this
              • 3580
              I have no idea... This is what they look like...
                • 34847
                yep, I think they raise the front of your car by about 1". try GC or vorshlag if you want to lose the gap.. or shorter springs and less travel (not a great choice).
                • rwh11385
                  lance_entities
                  • 18403
                  Looking at the picture, I would say yes. There's is an inch or two in that camber plate that you do not have in GC's...
                  • Hellabad
                    • 807
                    There is whole thread about this somewhere with pics. I can't find it right now. Search for billie bump.
                    But.. until then, check that you don't accidentally have 2 spring perches up top. But also, you may just be on the Bilstein bumpstops. The car will sit onto them sooner than you expect.
                    I have attached a pic of me pushing on Bilsteins until they bottom out. You will notice there is a lot of Chrome Bilstein shaft still showing, but inside they are stopped.
                    Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                    Ground Control Gallery
                    The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                    • Hellabad
                      • 807
                      here is a pic of the bumpstop inside.
                      • e30this
                        • 3580
                        hmm, I dont know. The plate is no more then 2 inches thick at most. Anyone have a pic of the GC plate installed and not in the car? I will look into it though.
                        • Hellabad
                          • 807
                          • e30this
                            • 3580
                            Im not running ANY bump stops. So if your shock is showing that much when it is bottom out then Im sure my shock is fully compressed because thats all that I have sticking out of the top of the shock.
                            This is what it all looks like installed.
                            Im going to pull shit apart and check it out later tonight...
                            • Hellabad
                              • 807
                              On the front Bilsteins, they are inside, you can't see them
                              Exactly. Thats why I posted the first pic, it is easier to understand.
                              Thats why I posted the second pic! Cut that with a steak knife, don't cut more than that.
                              Jay
