Spring pad question
  • sschin
    • 169
    Spring pad question
    I am going to stack the spring pads in the rear but i was wondering if i could stack the front upper spring pads?
    the suspension is lowering 60/40
    and i was thinking of putting a upper spring pad 9mm thick and rear one 10mm thick
    so it would be more like 51mm/30mm...
    because 60/40 with the reiger style front lip and my stock bottlecaps are going to be really low... any thoughts?
    325i LSDed, 17x8.5 et15 BBS CH's, Bilstein Group N Suspension
  • kencopperwheat
    King of Kegstands
    • 14396
    With a 40mm drop in the rear, I wouldn't double up on pads.
    Originally posted by Gruelius
    • sschin
      • 169
      so don't stack the rears just maybe put in the 10mm pad in place of the 7.5mm pad?
      Can the fronts be stacked?
        • 34844
        you should have no problems stacking the fronts. actually it should be easier since the fronts are just a flat doughnut shape, they don't have the nubs like the rear pads do.
        • kencopperwheat
          King of Kegstands
          • 14396
          I wouldn't add any pads to the front. A 60mm drop isn't going to drop you low enough to be damaging the lip.
          • sschin
            • 169
            OK thanks... I guess I won't put any pads in and see how it is... i just cancelled my spring pad order...
            Thanks for the fast responses...
            sschin
            • Mystikal
              Wheel Fitment Expert
              • 9602
              Whoa in an M20 yes it is. That is feakin' low, think where Jordan's lip is.
              • kencopperwheat
                King of Kegstands
                • 14396
                60mm is around 2.5". Jordan dropped the front of his car around 3 or even a bit more I believe.
                  • 37833
                  Just run stock pads all around and profile in to driveways and such, you'll be fine.
                  Grover Beach, California
                  BimmerHeads.com
                  • Nick325is
                    • 1409
                    A 3 inch drop on a cupkit? :shock:
                    Nick
                    • Digitalwave
                      is a poseur
                      • 6299
                      Jordan's front wheel gap is more than mine and I am lowered about 2.6-7".
                      RISING EDGE
                      • Jordan
                        • 12916
                        Wheel gap is not an accurate measure of drop. Wheel and tire sizes vary.
                        From the ground to the center of my front wheel well lip is 23.75in
                        From the ground to the center of my brothers eta front wheel well lip is 26in
                        https://mtechniqueabs.com/
                        • Digitalwave
                          is a poseur
                          • 6299
                          I think both of our overall diameters are very similar. And I measured mine to be 23.75 as well IIRC. So I guess we are even :)
                          Haha, I caught your post before the edit, saying your brothers car was 25.75".
                          RISING EDGE
                          • Mystikal
                            • 9602
                            See, according to what he just posted his car is lowered 57.15mm. Like I said, the same.
                            • Jordan
                              • 12916
                              The tire is half deflated. Its likely more then 26.
