how to get the front lower? H&R race.....
  • 1991 e30 bmw 318is
    • 523
    I just got my H&R race springs on a little while ago. They are used and I'm sure there fully seated in..... my bav auto springs sat better then the h&r's also have billy sports.... im happy with the back. but the front is to high. i don't think i want to remove the rubber pads... but i might how much lower will that make it? drop hats might be an option not sure where to get them and they might be to low.... some camber plates lower the front, which one will? and how much lower? probably want it about 1/2 or 3/4 inch lower in the front....... any ideas? ill try and get pics soon.....
    91 e30 318is M50 SOLD
    http://www.r3vlimited.com/board/showthread.php?t=149570
    92 325 vert project
    http://www.r3vlimited.com/board/showthread.php?t=341370
  • E30_fiend
    • Apr 2006
    • 7348
    There are a few options here.
    1. Camber plates- maybe 1/4-1/2 inch drop
    2. Cut one coil off of the front springs- varies in drop
    3. Drop hats- maybe 1/2 inch drop
    I would personally just cut a spring because its easy and it gets the job done. It will also make for a stiffer spring rate.
    Good luck
    Taylor
      • 523
      Good luck
      Taylor
      not sure about cutting springs... i like the ride just want it a little lower where do i get drop hats?
      92 325 vert project
      • reelizmpro
        • 9558
        Just take the damn spring pads out. You could do it in 3 minutes with a razor blade.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
          • 523
          how much lower will it go?
          92 325 vert project
            Maybe 1/4-3/8" for the spring pads.
            Before you lower the front anymore take a real good look at how little clearance there is between the ground and the oil pan. Then think about all of the things you could hit with the current ride height.
            • Stu
              • 4083
              Barry, my right thumb bears a painful reminder of cutting my old spring pads off IE springs years ago. I did it with a switchblade, and had my head over the hood while my hand was under the fender cutting the spring pad, just judging by feel. I didn't realize that my thumb was over the 'lock' button on the knife, and it turned 90 degrees on my thumb, blade went in over 1/2"!
              To the OP -- sounds like you just want the car on the ground so I'd say fuck it and hack off the top coil.
              • Philo
                Ich esse kleine Kinder
                • 3334
                In my opinion the best bet would be GC camber plates. It will lower the car in the range you want, provide more strut travel, and give you full adjustability on the front end. It's a win win in my book.
                -tim
                Originally posted by Jordan
                I like the stance
                  • 523
                  its an m50 and the oil pan is much higher then the m42. it was lower with my bavauto springs, and i had no problems.
                  92 325 vert project
                    • 523
                    that's what I'm thinking save my tires on the street, get to the track and set it up with my track wheels..... where is the best place to get them?
                    Jeremy
                    92 325 vert project
                    • Philo
                      • 3334
                      Best place to get them is directly from Ground Control. Unless you can find someone selling them used.
                      -tim
                      I like the stance
