318 springs on a 325?
  • jasonslackisrad
    • 269
    Hey so i got myself a set of 40mm drop springs from another forum, but i found out they are for a 318.
    they are progressive rate springs, but will they just not work?
  • M5wanaB
    • Aug 2007
    • 405
    They will probably work but you will get more of a drop than 40mm at least in the front. Also they may be a little on the soft side. Also I think the Early 318 has smaller diameter springs (these wont work) what brand are these?
    1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
    • jasonslackisrad
      • 269
      well, i wouldnt mind more than the 40mm drop, since they were supposedly 60mm springs.
      they are jamex, and the part number says they are for 82-90...so i think i should be ok on that end.
      im pairing them with billy sports.
      • wolfgangstbd
        • 960
        the early 318's have a different strut tube/instert size i think the spring is the same
        • reelizmpro
          • 9558
          Yeah the front shock inserts on 84-85 318i and 86-87 325 (I believe) was 45mm vs 51mm but springs are the same diameter.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
