Installed HR race springs Billy Sports and a 95 M3 rack with PS delete. any suggestions?
Crazy bumps steer with new upgrades
http://raceskids.com/Tags: None -
http://raceskids.com/Comment
you had it aligned, right?
were the spacers above or below the rack when you installed it?Comment
How much PS fluid did you leave in your rack? Also, what method did you use; alum block, ps line loop, 2 holes?
If there is too much fluid, it will be stiff as hell and jerk back because there is no room for the fluid to travel. On my PS delete, I left about an ounce of fluid in there.-tim
If there is too much fluid, it will be stiff as hell and jerk back because there is no room for the fluid to travel. On my PS delete, I left about an ounce of fluid in there.Custom Made Skid Plates For Sale.
I would try to let some fluid out to see if that helps the problem. The only reason the fluid is needed, is to lubricate the rack. A very slight amount will do, as the ATF fluid spreads easily.-tim
