call me crazy...but it seems like some air has got into my p/s system after doing my e-i swap. during the swap my power steering resevoir was pointed to the ground...and started leaking from its cap..i believe this is how the air got in the system. so i removed the cap and turned it lock to lock a bunch of times and saw air bubble coming to the top (in the resevoir) and then the fluid started to aerate (foamy bubble fluid). after continuously bleeding it (in the way which i thought was right) i still have this whining coming from the power steering
...ergh....what a pita...is there something i am doing wrong? maybe my pump is now done? it worked find before the swap now this...also i know when i removed the pump before i loosened some of the bolts on the pump trying to get her loose from the block...so the pump started leaking a little until i tightned the bolts back up. it still drips a little...maybe i fubared the pump...maybe im just so frustrated with it i am overlooking something simple..
any input would be nice
