top nut on the front strut assembly
  • rede30
    • 4697
    What are some good methods on geting this nut to loosen without spinning the strut. Is there a special socket bit that bmw sells? thanks
    Dustin
  • graphik
    • 361
    impact gun.
    • ///M Powered
      • Jan 2004
      • 1109
      Or have you freind hold a vise grip and turn it yourself with some muscle ;)
      • DanGillan
        • Mar 2004
        • 4061
        NO! dont vice grip the strut to stop the spinning, thats absolutely wrong in every possible way! impact gun, impact gun, impact gun, or just a lot of torque on a wrench somehow. you'll get it
        Dan
        • Digitalwave
          is a poseur
          • 6293
          Vice grips are fine as long as you are not re-using that strut.
          RISING EDGE
          • aaron_silva
            • 1785
            The strut would bottom out well before the spot on the shaft (where the vice grips are placed) enters in the housing. For example, when removing the RSM;s, the top part of the shaft can be held with grips and you can use and open ended wrech.
            There would be no damage done the the shaft.
            Aaron
            • Charlie
              kid tested, administrator approved
              • 6686
              Impact gun.
              -Charlie
              Swing wild, brake later, don't apologize.
              '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
              FYYFF
              • kansas-ix
                • Jan 2004
                • 1600
                8mm socket and needle nose pilers on the top.
                E30 325ix 62k
                • Jordan
                  • 12913
                  Impact gun ot vice grips both work.
                  https://mtechniqueabs.com/
                  • ryan_george
                    • Mar 2004
                    • 331
                    I somehow managed to strip the threading on a bilstein once :oops: using a socket wrench and hammer.
                    • Jordan
                      • 12913
                      Righty tighty lefty loosey.
                      • ryan_george
                        • Mar 2004
                        • 331
                        Lol, well I'm not that dumb
                        • hamann318is
                          • 3382
                          Impact gun. Should be no question what to use; it makes life easier.
                          The BMW 318 is back. With a vengeance.
                          • rede30
                            • 4697
                            an impact gun has been borrowed from a friend and i will use it tomorrow. thanks guys.
                            Dustin
