Just checking on how to adjust rear Koni SA
  • e9nine
    • 1890
    Originally posted by MattM20
    Originally posted by nando
    what kind of konis do you have? SA or DA? all the one's I've seen need to be compressed to adjust them, but they've all been SA.
    i have SA's with 3 damping settings in the rear. I'm positive ive heard of other people on this forum who have the same shocks as I do, but i guess they arent as common as i thought.
    Your's sound slightly different from mine Matt. Mine don't have PRESET levels. You select your own range. Mine are single adj. too and all I do is take out the little white ring, my excuse of a custom bump stop and just twist away.
      • 34844
      so you can't finely adjust them, it's just three presets? they must be older, unless they're just a completely different shock.
      I don't even remove the rear wheels to adjust mine.. I just back up onto a set of ramps, unbol them from the bottom, adjust and reassemble :)
      I can see the exhaust getting in the way of some of the lower cars with that method though.
      • MattM20
        • 641
        yeah just 3 settings, i guess i must have an older set although they were purchased less than 2yrs ago.
