Control Arm Replacement
  • llll1l1ll
    • 782
    I bet I could get my Dad to help me rig up a press (like we did last time). Otherwise, soap it is.
    Me: "I can't wait to redline my car!"
    Mark: "Didn't you just break a rocker arm?"
    Me: "Yeah, I don't think I've learned my lesson."
    Mark: "You never will."
    • 3bvert
      • 1032
      also helps to emery cloth off the paint, where the cab slides on
      • TheB1G Lebowski
        • 593
        great im about to springs/shocks/struts and guess im gonna get a kit from bav auto for the sway bars. But at the same time im gonna replace the lower control arms, CABs, strut mounts/shock mounts, and tie rods. Is there any thing else i should think about getting to replace?
        1989 325i - sold
        1987 RX-7 Turbo II - sold
        1990 325i
        • browntown
          • Jun 2004
          • 3524
          I've never been able to not tear the rubber with a pickle fork. Of course I've always used an air hammer instead of being gentle with a mallet.
          • ThreeTwentyFissel
            • Apr 2009
            • 220
            am just about ready to replace similar parts except am replacing all underneath bushings since its a 20 someyear old car. What else should one look at while doing this kind of job?
            Simplicity is your best option!
            • Fendego
              • Nov 2008
              • 124
              Just started this tonight. Honestly it feels like more work than when I replaced the engine. I've only got one side out cause the freakin old ball joint broke off in my hub and so I'm drilling it out. I got so fed up I decided to be done for the night. Its so annoying I wanna punch a baby but not really lol
              • JGood
                • Jan 2004
                • 7959
                Up front you have:
                Tie rod ends
                Control arm w/ inner and outer ball joints
                Control arm bushing
                Strut mounts
                In the back:
                Trailing arm bushings
                Subframe bushings
                Shock mounts
                That's about it. Then you have motor and trans mounts. Then the driveshaft center support bearing and flex disk. That should be about it for rubber parts.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • llll1l1ll
                  • 782
                  I just wanted to recap:
                  aside from the control arm ball joints (which come with the control arm), are there any other ball joints that I should be aware of?
                  • svn2002s
                    • Sep 2004
                    • 478
                    Don't forget the diff bushing and maybe the muffler hangers.
                    • JGood
                      • Jan 2004
                      • 7959
                      Originally posted by JGood
                      The tie rod ball joint is the only other ball joint on the car
                      • llll1l1ll
                        • 782
                        Ah!
                        I guess I should just get a new tie-rod assembly for that side in case the ball joint is busted on the tie rod, then, eh?
                        • ThreeTwentyFissel
                          • Apr 2009
                          • 220
                          Ah!
                          ***Yes sir! if your going to do work be sure is done right the first time!
                          • ThreeTwentyFissel
                            • Apr 2009
                            • 220
                            Up front you have:
                            Tie rod ends
                            Control arm bushing
                            Strut mounts
                            In the back:
                            Subframe bushings
                            Shock mounts
                            on the works...everything is ready for labor...:crazy:
                            • llll1l1ll
                              • 782
                              Turns out I do not need a new control arm as my car no longer pulls so hard.
                              The pulling was due to my extremely worn tires which have been replaced with new ones.
                              Could use a toe adjustment, though.
                              • RoadHazard
                                • Sep 2007
                                • 163
                                You will need new bushings. I'd recommend upgrading to at least the stock M3 bushings:
                                How do you align the hole when pressing the bushing onto the lollipop?
                                90 E30 S50B30
                                http://www.fquick.com/roadhazard/
