Will '87 325iS struts fit/work on an '88 325iS?
  • Ben Carufel
    • Jun 2004
    • 5248
    Am still working on the purchase of a track car and might need some front struts to drive it around a bit before I put a track suspension on it.
    Found a decent deal on a pair of front struts from an '87 iS. Will they work on the '88 iS?
  • Ben Carufel
    • Jun 2004
    • 5248
    Oh, and will the '87 strut housings fit the '88?
    Thanks!
    • kencopperwheat
      King of Kegstands
      • 14396
      They're interchangable.
      Originally posted by Gruelius
      • Ben Carufel
        • Jun 2004
        • 5248
        Thanks, Ken.
        AllOEMBMWParts.com lists the '87 and older and the '88 and newer struts as different part numbers.
        • kencopperwheat
          King of Kegstands
          • 14396
          Originally posted by Ben Carufel
          Thanks, Ken.
          Strange. You might want to measure the diameter of them. *Some* of the older 325 struts were 45mm, but most were 51mm.
          • kencopperwheat
            King of Kegstands
            • 14396
            AllOEMBMWParts.com
            OT, but I just checked them out and, damn they're expensive.
            • Digitalwave
              is a poseur
              • 6299
              Thanks, Ken.
              I wasn't aware ANY 325 model E30 had 45mm struts, only the 84 and 85 318i's.
              RISING EDGE
              • Ben Carufel
                • Jun 2004
                • 5248
                Yeah, I found a local R3V member who can get me two '87 iS struts (used) for about $50.
                That's all I need, since they're just to roll the car around and drive it to have the cage welded in.
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  Thanks, Ken.
                  Neither was I until Fred Kim said that his 84 325 had 45mm ones.
                  • Ben Carufel
                    • Jun 2004
                    • 5248
                    Where is this diameter measured?
                    • Digitalwave
                      is a poseur
                      • 6299
                      I believe its the inside diameter of the strut tube and/or the outside diameter of the strut insert.
                      RISING EDGE
                      • Ben Carufel
                        • Jun 2004
                        • 5248
                        Thanks.
                        I'll hook up with Neil and measure the diameters of his '87 parts and my '88 parts.
                        Need to get to Sears and pick up a new calipers soon anyhow.
                        • Ryan Stewart
                          I Love Miatas
                          • 8978
                          That is it Ben! I want a divorce!
                          Or at least stop asking me and come straight to the forums.
                          Im now E30less.
                          • Ben Carufel
                            • Jun 2004
                            • 5248
                            Just checking the info you give me.
                            Can't be too careful.
