Stupid Newb Front Koni SA questions
  • browntown
    • Jun 2004
    • 3524
    So I bought these things in a group buy like four years ago and I'm ready to install the koni yellows. The instructions suck and the parts bag is mystifying.
    - Do I put oil in the strut tube like the original boge's or put the inserts in dry?
    - My strut inserts didn't come with collar nuts, so I got one's from the dealer. Do I need to weld up a two pin wrench to tighten them, or to hell with it and use a monkey wrench?
    - Seems like they should have a boot of some kind to protect the shaft like the bilsteins do. Are there special Koni boots, or a oem part #, or just go to NAPA and ask for boots?
    Every now and then I get the compulsion to work on this thing, problem is the big time gaps in between where I forget all the details I've already researched.
    You're welcome to call me an idiot to my face at the picnic this year.
  • Hellabad
    • 807
    The instructions are Euro Pictures, which are not translatable to English, But you actually can figure out what they are talking about if you spend time looking at it. The triangle with the exclamation mark in it means "be careful"
    If you live in the PNW, and it is a street car, then use oil. I actually use ATF because it is red, and easily available, and when it leaks out a little bit, you won't freak out because you have a blown strut. (which will leak goldish oil instead of red.)
    If you have a race car, then there are facts (pro and con) on both sides of the oil in strut argument.
    Use really good Channelocks of you must, you will never find that pin wrench. When you install the struts and use the stock upper nuts (gland nuts) there is usually a metal colored ring in the Euro Hardware Pak, that goes on top of the Koni and under the top gland nut.
    Use the stock boot from BMW, which is around the bumpstop.
    Bookmark this page, and stay away from drugs.
    Just show up with Konis on the car. You will only be called an idiot if you forget to preadjust them before you install them.
    Jay from Ground Control
    Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
    Ground Control Gallery
    The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
    • browntown
      • Jun 2004
      • 3524
      front strut stack
      Jay, thanks for the help. Forgive the competitor plate in the photo (although that is a GC weld on m3 swaybar mount).
      Does this look like everything in order?
      From Bottom to top:
      Strut body
      ATF fluid
      Strut
      Collar Nut (the thing that screws into strut body)
      Lower rubber spring pad
      Spring
      Upper rubber spring pad
      Factory bumpstop with plastic dust shield hanging off the bottom?? Not sure I got the right parts here
      spring perch
      camber plate
      flat washer
      lockwasher
      top nut
      Also, I found these things on the bottom of my suspension box, and I'm pretty sure most of it came with the konis, but I don't know where they go. Any help?
      edit: I now realize the black metal spacer doohickeys below go on top of the strut body, under the collar nut -- right?
      • browntown
        • Jun 2004
        • 3524
        Well I'll just assume those white plastic washers aren't important and go with the stack outlined above.
        • Wh33lhop
          • 11705
          Sorry I can't be of much help, but I do assume that the oil in the housings with Konis is just to dissipate heat from the insert to the strut body, amirite?
          Those plastic washer things do have a purpose, but I don't remember what it was. I've ran several sets of Konis without using them with no real ill effect, for what it's worth.
          paint sucks
          • E30-M3
            • 141
            how much ATF do you use?
            88 M3
            90 325is
            91 M5
            • DRTSRFR
              • May 2008
              • 1836
              The white nylon split washers are bumpstop vents. In certain situations the bumpstop, when bottoming, can actually suck oil from the damper and ruin the wiper seal.
              Suspension tips here...
              http://www.r3vlimited.com/board/album.php?albumid=757
              • browntown
                • Jun 2004
                • 3524
                Bentley says 20-25ml of oil, Koni instructions *seem* to indicate 50ml of antifreeze.
                Either way we're talking about one to three tablespoons.
                50 ml = 3.38 US tablespoons
                • browntown
                  • Jun 2004
                  • 3524
                  OK -- I'll throw it on top of the collar nut then, under the bumpstop. thanks
                  • browntown
                    • Jun 2004
                    • 3524
                    So I figured I'd just throw it together. Here are some pics of how I think it's supposed to go together. If I f*cked up, please tell me now.
                    ATF, 50ml is too much, two tablespoons is plenty.
                    Grey spacer collar on top of koni strut
                    Collar nut screwed down as tight as possible with monkey wrench. Does not screw down all the way, I assume thats OK.
                    White plastic washer on top of collar nut.
                    Bump stop, with plastic shield hanging from the bottom?
                    Rubber spring pad, Spring, Top spring pad, vorshlag perch, camber plate, lock washer, top nut.
Name:	koni 001 (Medium).JPG
Name:	koni 002 (Medium).jpg
Name:	koni 003 (Medium).JPG
Name:	koni 004 (Medium).JPG
Name:	koni 005 (Medium).JPG
                    • browntown
                      • Jun 2004
                      • 3524
                      more pics.\
Name:	koni 006 (Medium).JPG
Name:	koni 007 (Medium).JPG
Name:	koni 008 (Medium).JPG
Name:	koni 009 (Medium).JPG
Name:	koni 010 (Medium).jpg
                      • browntown
                        • Jun 2004
                        • 3524
                        final stack
Name:	koni 011 (Medium).JPG
                        • TrentW
                          • 2815
                          Back from the dead thread...
                          Trying to confirm that it's normal for gland nut not to tighten all the way into the housing.
                          Been on perma-hold with Koni and gave up.
                          edit: I later saw on one of the diagrams from instructions that 1-4mm between top of strut "nut" and strut housing is okay.
                          • Northern
                            • 5092
                            Can you help?
                            Mine were the same as that picture. I can't see them making the insert short enough that you could possibly run out of threads. I think they're there as a buffer for manufacturing tolerances between housing/insert/spacer/gland nut.
                            The liquid is to some extent for both heat transfer out of the shock, and for corrosion prevention. Many manufactures use antifreeze instead of oil, but E30's use oil.
                            I feel like the only important point is to not mix the two.
                            Originally posted by priapism
                            Originally posted by shameson
                            • kidneylover
                              • Aug 2014
                              • 51
                              final stack
                              [ATTACH]26590[/ATTACH]
                              So we need that metal collar over the top of the strut and bump stop?
