IE camber plates
  • Bryson
    • 1490
    IE camber plates
    mine make lots of clunking noises over even to most miniscule bumps when I'm moving slowly. At speed, the noises and clunking feeling associated are gone
    Has anyone else had this problem? Did I leave something loose? My best guess would be that the shock itself isn't tightened down all the way.. I was in a hurry and didn't drive around to set them at all if necessary
  • Jordan
    • 12916
    Impact gun the main nut, see if it tightens up any.
    https://mtechniqueabs.com/
    • Digitalwave
      is a poseur
      • 6299
      Is the collar that holds the strut in the tube fully tightened? I had a problem with mine vibrating itself loose a lot, had to throw some loctite on it.
      RISING EDGE
      • Giorgio
        • 169
        e36 suspension ;) doesn't use inserts :)
        I impacted it on with a 3/8" drive impact but I think the special washers just had to seat themselves while driving, so I'll snug them down with a 1/2" impact tomorrow morning
        thanks guys
        edit: Bryson talking
        • kencopperwheat
          King of Kegstands
          • 14396
          Word. I checked mine out yesterday and the damn thing had backed All the way off.
          Make sure you have the washers under the main nut. Mine was making noise and the nut was all the way down... there just weren't any washers in there.
          Originally posted by Gruelius
          • Giorgio
            • 169
            beat you to it :D
            • cthulu703
              • Oct 2004
              • 288
              Mine have not made any noises since installing them two weeks ago. May be luck, but I prefer to think it's because everything I do turns out perfectly. ;)
