Re-valving Bilstein Sports
  • Jean
    • 18228
    For those who had this done, how long did it take and who did it?
    Did you opt to modify the internal bump stops, is that an option?
    Basically I want to make sure my shocks work in tune with the springs I have selected for my car and it's weight. Rates are 550front/675rear, car's weight is 2500lb w/o me in it.
    My current inserts I am sending back to Bilstein for warranty and will then sell them to purchase new / re-valved set. I don't want to revalve my current ones as the fronts are early 318 specific inserts of thinner diameter and my new strut housings are of the late model type.
    Thanks!
  • JeffRR
    • 277
    The aftermarket Bilstein division in Poway, CA can do re-valving for a fee.
    858-386-5900
    Not too sure if they would be willing to modify the bump stops though.
    • Jean
      • 18228
      Thanks you, got a couple more suggestions on bfc as well.
      • e30s50dan
        • Nov 2008
        • 2076
        They revalved my 944 track car bilsteins for $75 each. Good turn around. I think his name was France
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • Jean
          • 18228
          Spoke with Bilstein today... it's $65 per insert or 75 if they are struts... plus $10 if needed for seals iirc.
          The problem is they can't turn my 45mm front inserts into 51mm, nor do they have any 51mm inserts in stock.
          Not sure what I am going to do. Might have them rebuild fronts to factory / new condition and sell them (or sell all four and fund other shocks).
          The rears are the same, it's the fronts that are a downer.
          • 2002maniac
            • 4260
            I have a blown set of front sport struts I'll let you have for $100 shipped. They are pretty beat would work well as cores
            • kenika65
              • Aug 2007
              • 1336
              so this re-valving is pretty much rebuilding old struts?
              1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
              1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
              • Jean
                • 18228
                I was just going to post a WTB ad, but just how beat are they? They need to be good enough where they can rebuild/re-valve them though.
                Any rust, or how badly damaged are they?
                Thanks
