Drop Hats.....
  • Philo
    Ich esse kleine Kinder
    • 3334
    #181
    I would like to point out that the E30 hats have an angled seat for the mount, where the E90 hats do not. Not sure if this could change anything/add problems/make spring seating uneven.
    Also, the strut ring on the bottom of the E90 hat is interesting.
    -tim
    Originally posted by Jordan
    I like the stance
    • richardkeith97
      • 1693
      #182
      the hole in the center is also not in the same spot
      • JGood
        • Jan 2004
        • 7959
        #183
        Horizontally or vertically? I didn't take notice, or even think to measure, when I installed mine.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • Philo
          • 3334
          #184
          I have both hats in front of me, the holes are both in the same location. The E30 hats have an angle built in like I said.
          -tim
          I like the stance
          • bmwstephen
            • 2463
            #185
            ^^ thats interesting.. does the stock hat have an angle too?
            • Philo
              • 3334
              #186
              The stock hat is on the right, and the E90 hat is on the left. The stock hat has angle, the E90 hat does not.
              -tim
              I like the stance
              • bmwstephen
                • 2463
                #187
                oh woops. I was trying to see if Richard's versions had an angle, I didn't recall
                • mkcman17
                  • Jul 2010
                  • 8240
                  #188
                  I just installed e90 hats. So far so good. Not much noticeable difference in drop imo.
                  1989 LN106 Hilux / 3.0TD SFA
                  1974 2002tii / stock
                  2002 IS300 / 5spd LSD
                  • ethrtyiS
                    • 8147
                    #189
                    would have been if you removed your pads. ;)
                    「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
                    「my feedback thread」
                    • DrFraserCrane
                      • 605
                      #190
                      IE3 springs, drop hats, no pads up front, lower pad left in on the rears, stock tires on 14" weaves.
                      • 325e10
                        • 161
                        #191
                        Bilstein BTS kit, e90 front hats no spring pads, only top pad in the rear.
                        • immajackuup
                          • Dec 2010
                          • 1132
                          #192
                          is e90 hats the same as richard so call drop hats?
                          • george graves
                            • 20003
                            #193
                            No. His are deeper.
                            Originally posted by Matt-B
                            • wille28
                              • 113
                              #194
                              can we run drop hats on coilover?
                                • 34847
                                #195
                                no point with coilovers, they don't usually use the stock perches either way.
