Drop Hats.....
  • Mushroom Stew
    • Dec 2014
    • 121
    #286
    This washer people are talking about, is it a OEM BMW part? Part #? Wouldn't mind ordering a pair with the drop hats just in case
    • Terroth
      • Jul 2014
      • 22
      #287
      Do the springs remain captive when these are installed?
      • george graves
        • 20003
        #288
        Yes.
        Someone else asked if it changes handling. It does not. All it does is move the top of the spring up 1/4" or so. There is no geometry changes. You'll feel more difference with a change to new tires then this.
        Originally posted by Matt-B
        • ///digitalme
          • Dec 2009
          • 2088
          #289
          I have the e90 drop hats and i think boge strut mounts, installed just like stock for about 3 years and from time to time it binds. Im redoing my suspension im going with sachs mounts this time to see if i eliminate the binding issues
          • bimmerR75
            • Jan 2016
            • 251
            #290
            Reading through 20 pages of back and forth. Seems everyone is running different suspension setups. Is there a noticeable result if you keep stock springs, stock struts, etc and change out to the E90 OEM drop hats? Debating whether or not to do this, or just buy H&R Sports and call it a day.
            I use mine as a daily driver so just want to get rid of the horrendous wheel well gap in the front. Running 14" with an IS valence and lip.
            If I had to live my life over, I'd live over a Saloon" - WC Fields
            Garage
            1991 325i
            1972 R75/5 Cafe
            • tiagozone
              • Jun 2016
              • 39
              #291
              Hi. i have jom coilovers installed in my e30. If i buy a set of drop hats, will they work ?
              Joms coilovers are similar to raceland coils.
              • wworm
                • Dec 2016
                • 1719
                #292
                Wheel gap's gonna stay with 14" anyways. H&R sports are a good dailyable height but look sorta goofy with 14's. Definitely better than stock height though. I put springs on before wheels and it definitely made me like the car more but wheels have been the biggest "look at my car and get stoked" purchase so far.
                1984 Delphin 318i 2 door
                • donahue1980
                  • Mar 2015
                  • 119
                  #293
                  I’ve been searching the thread and forums to find a set of camber plates that will work with e90 drop hats, but can’t find much. I’m running Bilstein HD’s with H&R OE springs with e90 drop hats. Any camber plates recommendations? Thanks. - Tom
                  • Shu
                    • Nov 2015
                    • 132
                    #294
                    On my last E30, I used a set of SPC camber plates with E90 drop hats - https://store.vacmotorsports.com/spc...ates-p208.aspx
                    Ground Control also makes a set of camber plates compatible with OE spring hats - https://groundcontrolstore.com/colle...nt=42803062531. I have a set of these and will be using them on my current E30, also with drop hats.
                    Zelig the Zinno • 300k and counting
                    http://instagram.com/zelig.the.zinno
                    • donahue1980
                      • Mar 2015
                      • 119
                      #295
                      Thank you, Shu!
