Bilstein/ GC
  • 619E30
    • 1753
    Bilstein/ GC
    I am about to order the ground control spring set and was wondering if they would pair well with bilstein sports?
    Originally posted by audiquattrot
    bimmers b4 b*tches....remember that.
    1990 Alpinweiss 325i - secret 500whp build
    2000 Audi S4 B5 Laser Red
    1990 Nissan 240sx - Drift Missile
    2006 CBR600RR
  • 619E30
    • 1753
    Anyone?
    2006 CBR600RR
    • White325is
      • Oct 2006
      • 5947
      yes.. just fine..
      • Philo
        Ich esse kleine Kinder
        • 3334
        Just don't expect to be slammed. The Bilsteins will bottom out after awhile. You can cut the bumpstop and get GC plates to gain more room though.
        -tim
        Originally posted by Jordan
        I like the stance
        • 619E30
          • 1753
          Alright sweet or should I just wait and save for a ground control kit?
          2006 CBR600RR
          • Philo
            • 3334
            It all depends on how much you want to spend, how low you want to go, and how much work you want to put into it.
            -tim
            I like the stance
            • z31maniac
              • 17566
              Yes.
              You will be able to go lower, more comfortably and with damping setup to be low on an E30. Not to mention camber plates are nice to have.
              www.gutenparts.com
              • 619E30
                • 1753
                Yeah, I want to drop it at least 2 inches
                2006 CBR600RR
                • z31maniac
                  • 17566
                  Shortened housings with camber plates will allow you to go even lower than that if you desire.
                  www.gutenparts.com
                  • sticksdaman
                    • Apr 2005
                    • 2987
                    I have GCs with plates and bilstein sports. The ride is amazing, I think its the ultimate dd coilover config.
                    You can drop atleast 2 inches with the ground controls/bilsteins alone.
                    Originally posted by ebelements
                    Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                    • 619E30
                      • 1753
                      I think I'll do that for my DD and save the gc kit for my track car
                      2006 CBR600RR
                      • BMW_TUNER
                        • Jul 2006
                        • 1386
                        I run the GC on Bilsteins just because my 5 lug front came with fresh Bilstein struts. i agree it rides great.
                        1989 332IS -S-Fiddy Four-Some weight removed.
                        5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
                        • ian e30 318is
                          • Mar 2007
                          • 1809
                          What rates are you guys running with your bilsteins? and did you cut the bumpstops or just leave them?
                          1991 LS1 Swapped 318is
                          Instagram:
                          https://instagram.com/saltybeast/
                          LS Build Thread:
                          https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                          • LivingLegend06
                            • Dec 2006
                            • 1604
                            Can you run shortened housings with bilstein sports? Ive done Ground Controls before and have no problems shortening the housing again, I just don't know how much is safe to take off with Bilstein sports, last time I had short konis in the front so I had room to take as much as I wanted to. This time I'm trying to do a budget setup.
                            • E30_fiend
                              • Apr 2006
                              • 7348
                              Im running 600fr and 750rr with bilstein sports all around. I cut the front bumpstops and dropped it even more.
                              bilsteins are designed for factory housing so the answer is no, you cant run them in shortened housings. Once you cut the housings you will need shorter struts and spacers for the housings.
                              Taylor
