BC Racing Coilovers: Installed and Tested.
    Well thought out huh? looks more work then tought into..? Love the adjusted spring sett do!! nice find!!
    Simplicity is your best option!
      that bottom piece that is welded to the casting is the new strut tube. your cartridge with the spring assembly threads into thatwhich is what adjust ride height.
      i dont know how many of you actually read the review, but i covered this in one form or another.
      My feedback:
      http://www.r3vlimited.com/board/showthread.php?t=186328
      http://e30tech.com/forum/showthread.php?t=74911
      Instagram:
      @gears_n_glory
      @functionmotorsports
        I didn't read shit my friend. :D
        John F. Kennedy
          Whats the OD on the shock cartridge? I'm fairly sure it will be bigger than your standard Koni or Bilstein insert. Hence the advantage these have over something like GC's.
          - Chris
          Project M42 - 255 @ 19 psi
            the OD of the cartdridge is 53mm
            My feedback:
            Instagram:
            @gears_n_glory
              How can you accurately place that threaded component onto the spindle assembly? Did you make a jig? How do you expect tire wear to be with that kind of variable?
                i was waiting for that question. the welding was done by a machine shop, and they measured and marked off everything.
                aside from their precision, you cut the oem tube and leave only 2 inches of it on the spindle which centers the new strut tube as it slips over the oem tube.
                My feedback:
                Instagram:
                @gears_n_glory
                  that and the fact that in order to lower your car, you do not decrease shock travel by moving the spring perch lower on the strut as the gc/koni combo does
                  My feedback:
                  Instagram:
                  @gears_n_glory
                    pictures?
                    Originally posted by ebelements
                    Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                      how much are they paying you?
                      if they gave you a discount or what not for the review cool but be up front about it
                        now you can go drift with cool coil over kids yo!
                        7speedshop.com
                          I'm always scared when ppl cut up the stock strut that far down. Not just welding to cast is dangerous, but the angle of the strut tube drastically effects so many things. 31 way adjustable means crap to me. I want to see a shock dyno plot of those shocks.
                            do they give you a jig? have anymore pictures. i loved my bc's on my gc8. i've been looking at these for a few weeks now
                              Which is why they use a shorter insert (revalved G60) and spacer setup to retain suspension travel.
                              Just want to prevent the constant spread of misinformation so prevalent on the internetz.
                              www.gutenparts.com
                                i was not payed or offred anything at all, i am doing this because the product is good.
                                My feedback:
                                Instagram:
                                @gears_n_glory
