Ground Control guys - Who uses 4" rear springs to get low ??
  • xwill112x
    • Jan 2009
    • 4236
    Originally posted by Karlspackler
    Right guys but the adjuster also keeps the spring centered.
    You dont think the springs have a chance to move around while compressed? That is what I am scared about.
    nope, if cut springs don't, these wont.
    • Karlspackler
      • Jun 2006
      • 510
      hmm, I guess I didnt know guys actually ran without the adjusters. Anyone else doing this that can vouch?
      • bataangpinoy
        • Jul 2008
        • 1636
        i run without adjusters on a 6 inch spring at 675 lbs in the rear.
        My feedback:
        http://www.r3vlimited.com/board/showthread.php?t=186328
        http://e30tech.com/forum/showthread.php?t=74911
        Instagram:
        @gears_n_glory
        @functionmotorsports
        • whodwho
          • Jun 2008
          • 1547
          I run a pair of these from IE to keep them centered:
          Spring Pads - Rear for small diameter springs
          SKU - e30springpad $12.00
          New Product- These are urthane rear spring pads for 2 1/4" to 2 1/2" ID springs. These locate the springs properly when using the smaller diameter racing springs. Priced each. You would normally need 4 per car.
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • e30fish
            • Oct 2009
            • 332
            What size ID are you using with those 2.5 or 2.225 spring? Can i see pics of the car from the side to see fitment and are you using spring pads?
            Im interested in doing this as well. Not looking to slam the car as im gonna run CG's w/475 fronts on the stock perches w/Koni inserts. BTW, my rear Koni's are revalved, but not shortend
            • e30fish
              • Oct 2009
              • 332
              Originally posted by E30_fiend
              yeah but a 4" spring WITH the adjuster is like a 5" or taller spring after its installed. I run a 5" spring with no adjuster and Im tucking a lot of rear tire on a late model.
              Taylor
              Can i see pics of your car from the side as well? Are u running spring pads, 2.5 or 2.25 ID spring?
              Also, are u guys buying regular Eibachs used in the CG's or getting something like Hypercoils?
              • IDM
                • 753
                Anyone have a picture of what these look like?
                • bataangpinoy
                  • Jul 2008
                  • 1636
                  im not using GC, but my springs are 60mm ID
                  My feedback:
                  Instagram:
                  @gears_n_glory
                  • S&E30
                    • 83
                    You only remove the adjuster not the threaded tube. That way it is still somewhat centered and it won't pop out if that's what you're worried about.
                    • AlarmedBread
                      • Sep 2006
                      • 1510
                      No adjuster, tube etc. Just the stock rubber top mount nipple thing to keep it kinda centered. No issues. Not ideal for performance, but who cares?
                      • S&E30
                        • 83
                        Word, that top mount thingy will keep it centered anyway. I was going to say that in my previous post but I got lazy. If you have GC, that nipple thing keeps a good hold of the spring from my own experience.
                        • whodwho
                          • Jun 2008
                          • 1547
                          Thinking about it tho, they maybe as thick as the GC adjuster... You might be able to get a couple more of the GC plastic cones??
                          • E30SPDFRK
                            • 5693
                            I run just spring in the back, no adjuster, no tube, no pads. It's been fine so far for the 1000 or so miles I've had it like that. Just cant catch air with the car, lol.
                            Byron
                            Leichtbau
                            • Stephen
                              Шлем ишака
                              • 10774
                              Ive run no adjuster , with and without pads. No issues.
