Steering Guibo FAIL!!>!>>!>!! VIDEO!!
  • badvibrations
    • Feb 2007
    • 447
    Originally posted by Philo
    Good point. How are we to solve this problem? Poly guibos or just replace the rubber one every so often?
    or...
    For only $105
    Equal rights should be all or nothing, not picked and chosen based on what's convenient for ones personal agenda.
    • Burnera
      • 137
      Originally posted by kronus
      IANAEngineer (well I sort of am) but it seems to me that the steering guibo is there to be weaker than the universal joints that surround it, so that it wears instead of them... replacing it by a hard link will probably disintegrate them much faster.
      I think this function is kind of secondary. My logic tells me it's there to filter out vibration and bumps to the steering wheel. BMW's are supposed to be comfort rides too, not bone smashing race cars.
      • Dominic49
        • Feb 2007
        • 1373
        vibration definitely seems first.
        that is E36 only at the moment they are working on an e30 version though....
        • M-technik-3
          • 18946
          Works with E30, E36 and E46 BMW steering racks.
          This is a bolt-on steering U-joint is CNC machined from ChromeMoly Steel, and makes for a low profile needle bearing U-joint to allow precise steering inputs without the factory "Rag Joint". This is "made for off-road use".
          • Philo
            Ich esse kleine Kinder
            • 3334
            I don't see how that would be any different than Dominic's setup. Just a solid link unless I missed a bushing somewhere in there.
            -tim
            Originally posted by Jordan
            I like the stance
            • newman
              • Mar 2007
              • 1159
              You need 2 of those DD shafts, so it's like 210 + the shaft...
              1987 325is: 495whp/400ft-lb
              UPDATED 03/12/10!: RB26DETT Swapped E30
              • badvibrations
                • Feb 2007
                • 447
                Aroo?
                From that page..."Works with E30, E36 and E46 BMW steering racks."
                Good Eye.
                • psyber_0ptix
                  • 904
                  hmmm..... maybe time for a steering quickner mod if replacing all the shafts and ujoints anyways?
                  Originally posted by FredK
                  However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
                  My year in Germany
                  Feedback
                  • Burnera
                    • 137
                    Just might actually be cheaper than hunting for a Z3 rack too.
                    It's pretty common for those gearbox quickeners to add some dead space in the steering wheel, but usually only like 5*. Still a lot less than the guibo adds in the OP video. :D
                    • lonestar22
                      • Aug 2005
                      • 417
                      thats scary, that happening at the wrong time could be bad news
                      Originally posted by Lof8
                      Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        Is this only an issue for guys not running PS?
                        • Jean
                          • 18228
                          I picked up a new guibo a few months back to make everything ready for the steering rack swap, but now I can't find the u-joint hardware haha.
                          I wonder if some of the dead play is from the stock guibo wear and not so much from the e30 rack itself...hmm.
                          • Adrian_Visser
                            • Jun 2006
                            • 2823
                            I've been pondering in my head whether or not to replace this piece when I do my Z3 rack swap for a while. I guess this is sufficient motivation to replace it.
                            '89 Alpine S52 with goodies
                            • Aerton
                              • Oct 2006
                              • 729
                              Rag Joint Guido
                              Old thread with some good advise, I'm about to do a rack swap going with an e36 M rack.
                              I have been reading about the Rack swap and have a couple of questions.
                              Do you guys recommend the Zionsville kit for $89 that includes the rag joint. Or should I go for the kit minus the rag joint and buy the urethane one from Ireland Engineering.
                              Let me know your thoughts, is the urethane one to much for street use?
                              http://store.nexternal.com/ireland/s...hane-p619.aspx
                              WTB-Strut Bar
                              • SkiFree
                                • Jun 2011
                                • 2766
                                The new E30 sized urethane mount is found here......
                                ADAMS Autosport
