Front Control Arm Bushing Removal Tool
  • monty23psk
    • Mar 2008
    • 1289
    Hey guys,
    Finally decided to post up for rent the front control arm bushing removal tool set. This tool is used to remove and install the control arm bushing from the control arm itself. This tool is NOT to remove the bushing from the lollipop. The lollipop will come out with the bushing when you use this tool. This tool does each side removal in 5 minutes and the installation of the OEM or M3 OEM bushing back on to the control arm w/ lollipop in another 5 minutes. If you use urethane ones, you probably don't need to use the tool as it should slide in.
    Here is are a few pics.
    This is a pic of the tools:
    Here is the tool being used on my car to remove it from the control arm;
    The price for renting is $25 for the tool set. Same rules apply as for the subfame tool....
    Rental fee $25 per week (7 days) plus shipping. Another $75 deposit that will be returned minus shipping cost. $15 for every week after. Will ship either FedEx or UPS and supply tracking. Return must be the same. I will not split the tools apart. Day 1 starts the day after the part is received. Must be shipped on the eighth. Only will do Paypal.
    Any quesitons let me know.
    Alex 88 m5 | 91 318is | 19 Subaru Ascent
    BMW Tool Rentals & Fender Roller
  • monty23psk
    • Mar 2008
    • 1289
    Bump
    • joeblow
      • Mar 2007
      • 18
      Still available for rental, Alex? TIA - Pat
      • monty23psk
        • Mar 2008
        • 1289
        Yup, I just got it back last week from the latest rental. PM if you have questions or would like to proceed.
        • dude8383
          • Jan 2005
          • 10387
          PM sent.
          • monty23psk
            • Mar 2008
            • 1289
            Replied
            • joeblow
              • Mar 2007
              • 18
              Will do, and thanks
              • iwantspeed
                • 3164
                i made a diy for a bmw website and posted this link at the end,
                How to remove control arm bushing from lollipop Common symptoms for worn out bushings: brake shudder alignment out of spec uneven tire wear poor road feel Tools hack saw vice chisel hammer Parts spare set of lollipops control arm bushing mounts new set of bushings   remove the blade if you need to, draw an arrow so you
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • fporro
                  • 1860
                  man, you can cut the rubber with metal snips, then hack off leftover ring on arm, same for leftover in lollipop, takes less than 5 minuts each, zero efford.
                  • monty23psk
                    • Mar 2008
                    • 1289
                    http://garagistic.com/index.php?page...rom-lollipop-2
                    Thanks man.
                    • joeblow
                      • Mar 2007
                      • 18
                      Used these over the weekend, and they made the job very easy. Yes, you can do it a number of other ways, but this way allows you to change the bushings without removing the control arm. In other words, just by setting the car on jackstands and going to it. Don't even really need to get under the car, for those squeamish folks like me, you do it all from the side of the car. Highly recommended.
                      • monty23psk
                        • Mar 2008
                        • 1289
                        Tool back and available....
                        • winter_baby
                          • Jan 2015
                          • 3
                          Hello, Is the tools still available for rental? Plz PM me. Thanks!
                          • monty23psk
                            • Mar 2008
                            • 1289
                            Yes tool is ready at the moment.
                            • noypi2
                              • Jun 2014
                              • 442
                              I Need this tool. I just need to find time to do it.
