I'm gonna need this tool very soon :)
Front Control Arm Bushing Removal Tool
Its available. Just got it back last week.Alex 88 m5 | 91 318is | 19 Subaru Ascent
BMW Tool Rentals & Fender RollerComment
Just an FYI, this will work to remove/install e30 CABs, but will only remove e46 CABs (can't be used to reinstall). Not that it matters to most of you, but I tried to use it on my e46 and ended up banging them on with a hammer :DComment
These are great tools, saved me sooo much time and effort (I unfortunately did this job without them a while back.)
5 Stars/A+/:thankyou:Comment
Ok i've recieved some mixed info so I need to clarify.
I purchased a set of revshift 95A m3 offset bushings, and I was planning on cutting the OEM bushings off the control arm then sliding on the revshift bushing (my understanding is it does NOT need to be pressed onto the lolipop, should slide on by hand). The main concern is getting it back onto the LCA, will soap and muscle work or will I need this tool?//contact me for your marketing & design needs//
You can cut the old ones out but it can be a pain if doing it with control arm still on the car. The cool part of the tool is that it can be done without removing the whole arm out of the car. Remember you have to cut the very thin outer ring and then you can chisel/punch it out with a hammer. Doable but can add another 30min to an hour if you have done it before to each side. The tool is used to remove the bushing/lollipop from the control arm. Takes 15 minutes per side for removal and the same for installation.Ok i've recieved some mixed info so I need to clarify.
With urethane type bushings, they can go one with some force, no need for the tool to be honest. The tool is meant for the OEM rubber bushings, M3 included for the removal and installation. I used them for the removal and then pushed my AKG urethane ones by hand or a small mallet.Alex 88 m5 | 91 318is | 19 Subaru Ascent
Yup, currently available. Let me know
Sent from my SM-G950U using TapatalkAlex 88 m5 | 91 318is | 19 Subaru Ascent
