anyone make 10mm lowering spring hats
  • Jason89i
    • Sep 2004
    • 875
    ive completed the 5lug conversion with the e36 tidbits, but my front ride height is a little too high. about 1/2" highter that before. does anyone make the lowering spring hats for the e36m3? bmp used to have them....but i cant find them anymore. thanks in advance. jason
  • NC325iC
    • Mar 2004
    • 6565
    i want some for my e30 app too
    • royalflush313
      • Mar 2004
      • 2070
      I dont know about E36s, but Bonrath makes 10mm drop caps for E30s.
      ~ Go Canucks Go! ~
      • BahnE30
        • 1050
        IIRC ireland made they, i'm not sure on this so look around, but i know bonrath makes them.
        • egk2
          • 2426
          bekkers carries supersport24.de's spring hats that they claim to lower by 10-20mm, they're $59.
          • Jason89i
            • Sep 2004
            • 875
            Thanks for the input. I'm currently using e36m3 spring hats (with e36m3 bilsteins and e30 h&r springs.) Spring diameter on the two is the same, but spring height / spring hat offsets are different. The stock e30 spring hats have a 23mm offset (spring sits 23mm past the mounting washer)....anyone know the stock offset on the e36m3 spring hat? Is the spring hat different on the 95 vs the 96+? Thanks in advance. Jason
            • NickP
              • 257
              If you're using the e30 springs wouldn't you be able to get away with using the e30 strut mount and spring hat?
              • Jason89i
                • Sep 2004
                • 875
                yes, you can use the e30 spring hat and bearing, but you will be forced to use camber plates. camber plates usually add another 1/4" - 3/8" height. I built-in the caster by modifying the e36m3 bearing cap. (ground off the studs, redrilled, tacked on new studs....see 5 lug write up.) If my memory serves me correctly, the e36m3 spring hat has a greater offset (for lower ride height) than the e30. If thats true, the e30 spring hat would add ride height. Unfortunately, i never measured offset height on the e36m3 spring hat before i installed it. So I need to know what the oe e36m3 spring hat offset is to compare with the oe and reduced ride height spring hat. Overall im looking to loose 1/2-3/4" ride height. Cheers, Jason
                • NC325iC
                  • Mar 2004
                  • 6565
                  who or what is bonrath
                  • Mystikal
                    Wheel Fitment Expert
                    • 9602
                    The GC and IE (the more expensive IE ones) plates will actually lower your front end.
                    • Bryson
                      • 1490
                      for use with coil over suspensions ;)
                      • Mystikal
                        • 9602
                        Small detail. :oops:
                        Hope I didnt get any hopes up.
                        • NC325iC
                          • Mar 2004
                          • 6565
                          any website i can look for these at
                            • 34837
                            yes they exist but they are garbage.. buy different springs if you want to lower your car more or camber plates as mentioned above. TJ had the 10mm hats on his car and I bought a set to experiment with but I ended up selling them for $25...
