Does M3 rear sway fit a standard e30?
  • evilnickwong
    • Aug 2007
    • 302
    As title, does the rear sway frmo an M3 fit a standard E30?
    This is a picture, the seller here says that its from an e30 M3 and the arms are abit longer than the normal e30's arb?
  • blefevre
    • Dec 2008
    • 4287
    Yes, you can replace your stock bar for a E30 M3. At least I can on a late model. It's the exact same bar as the iX as well. The end links are the exact same too.
    - E30, DSM, Golf R, Mazda 3 Skyactiv
      • 34827
      it's not longer, it's just thicker. dimensionally it's exactly the same.
      • xwill112x
        • Jan 2009
        • 4236
        idk why people always want to upgrade the rear sway.?
        just do the front and leave the rear stock if you want a great handling e30
        • evilnickwong
          • Aug 2007
          • 302
          OK, thanks for the info guys.
          xwill112x: In my case, I want to buy this sway since my 318i M40 came stock with no sway at the rear. :) And I don't want to get an aftermarket sway because as you mention, it makes the rear too stiff. I plan to go aftermarket front tho. :D
          • xwill112x
            • Jan 2009
            • 4236
            sways in the rear usaully make over steer annoyingly common, and snap over steer all the time is no fun.
            • evilnickwong
              • Aug 2007
              • 302
              But I'm sure a stock M3 bar is not excessively large?
              I'll be running a 21 or 23mm bar in front as an upgrade to my stock 18mm.
