Ground Control help
  • Sirotto
    • 319
    Ground Control help
    So I have a set of the Ground Control conversion set up sitting inmy garage. I took them on trade on some other parts so they cam with no instructions and GC is kinda stingy on the info they will provide. I am going to be running billi sports with these. Do i need to cut the strut tubes or not. If I do how much do i cut out and then what is teh measurement from the top to weld my collar. If no cutting is needed how far down do I weld teh collars. One more what is the the body leanght of teh billi sports compared to factory boges.
    "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
    "People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
  • AbsorbantNut
    Non faccio funzionare questa merda
    • Jun 2010
    • 2491
    Theres a DIY in the DIY section. It was bumped recently so it should be close to the top. I'll buy them though if you want to sell them and save yourself the trouble:o
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
    • F34R
      sLaughter
      • 12376
      PMed, hope that helps.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • skatingzooyork
        • 251
        I'm kinda surprised that you had a problem talking the GC about it. Their CS seems to be their best feature from what I've read!
        http://www.jfalesphotography.com
        91 318is m50nv - New toy/project
        95 540i - Wife's DD
        • F34R
          sLaughter
          • 12376
          I know right? I called and talked to Jay(awesome guy) r3v member too"hellabad" He shot the shit with me and I am now going with the camber plates I need. They are cool and know what they are talking about.
          Current cars:
          ~ '87 535
          ~ '06 X5 4.8is
          • Sirotto
            • 319
            That did helps thanks.
            When I called GC they were not real resposive to my question because I did not buy them from them. I took some pictures of my system to show that it was theres and they send me some hand drawn sketches with no measurements.
            I have already cut the spring perches off. What i was wondering is if I needed to shorten the shock tube housing the inch like the DIY here mentioned. I do not plan on slamming the car, its my DD. Right now I am running HR sports with some old ass Billies. My plan is to go over to the GC with a newer set or Billies. I know Billies never were out but these have had it. Someone told me they will rebuild them but the turn around time is just too long for me.
            So just to clearify, clean up the weld from the orginal spring perch, set new collar from GC on old perch, weld, paint and go correct. No need to cut the one inch out shock tube housing.
            • psyber_0ptix
              • 904
              did you get a set of allen keys and a spanner wrench when you ordered your groundcontrol set? When I called, they said the e30 kit does not include this...which makes adjusting height a bit more troublesome. It comes in the e46 kit so i used a buddies :/
              Originally posted by FredK
              However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
              My year in Germany
              Feedback
              • F34R
                sLaughter
                • 12376
                Nope, no need to shorten them. Just put the Billy sports in and get the springs and shit all together and you are set.
                GL
                ~bRANDON
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
                • Sirotto
                  • 319
                  GL
                  ~bRANDON
                  Thanks Brandon
                  • drumad
                    • Aug 2009
                    • 1700
                    weird.. I got one allen key. No need for a spanner wrench however.
                    2008 335i - n54b30
                    1991 318i - m52b28
                    1994 fzj80 - LAND CRUSHER
                    • F34R
                      sLaughter
                      • 12376
                      1+ I cannot believe people are complaining about not getting allen keys. If you don't own a set of allen keys you don't belong installing them!
                      Since when was it hard to loosen the screw and raise and lower the spring platform?
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                      • Sirotto
                        • 319
                        One more question, I am missing the white cones for the rear springs. GC doesnt want to sell me any replacemnts either. Any direction I shoulkd go to find somethat will fit? You said that Jay is a member here, what is his screen name, I will try to contact him.
                        • drumad
                          • Aug 2009
                          • 1700
                          I really don't under who you're talking to that's refusing to sell shit to you.
                          his name on here is hellabad
                          if you can't get em from them for whatever reason..
                          just buy the upper spring pad for small dia springs from IE
                          http://store.nexternal.com/shared/St...S=ireland&All=
                          2008 335i - n54b30
                          1991 318i - m52b28
                          • VicSkimmr
                            • 687
                            They don't sell their kits piece-meal. I'm not surprised they won't sell him any replacement parts. If he had bought it directly from them he might have had a shot but since it's second hand they probably don't know for sure that he's not just some guy trying to buy a few parts of their kit.
                            Jason
                            flickr
                            • drumad
                              • Aug 2009
                              • 1700
                              well if that's 100% the case, go with the IE pad.. I'm sure other companies sell the piece but IE was the first that came to mind
                              2008 335i - n54b30
                              1991 318i - m52b28
