The suspension setup/ride height thread
  • Wiglaf
    • Jan 2007
    • 1513
    #451
    ok so i'm not happy with the cosmo coilovers, too stiff for the streets around here. and the rear adjusters are topped out but i still have too much neg camber. Winter is coming and I'll have to be driving this thing so a little extra height will be good.
    The rates on cosmos are 450lb/in 6" front, 560lb/in 5" rear.
    seeing as the stock 325is rates are 118/265 that's more like 1:2 ratio. So I have an idea..
    Move the front spring to the rear. That gives me an extra inch and lowers the rate a little bit. Then buy a 200# 7" spring for the front.
    This should give me softer, taller ride and I only have to buy 1pr of springs.
    and 200/450 is actually really close to the 118/265 ratio.
    What do you guys think?
    Originally posted by u3b3rg33k
    If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
    • JRKOUPE
      • Dec 2004
      • 3159
      #452
      your numbers are a bit confusing.....
      your current rates are good imo..its a very common street set up...maybe its the shocks?...
      a 1 : 2 ratio is not correct.
      HR race....GC's suggesdted rates...etc etc.. are not 1 : 2.....
      use 450/600 as a PROPER ratio.....and try like a 300 oR 350 FRT.....U CAN Figure out the rear
      my Hr race are like 350 ish and 550 ish rear iirc...
      • Wiglaf
        • Jan 2007
        • 1513
        #453
        Not to argue but I want to cut WAY back on how stiff the ride is. The roads around here kind of suck. Potholes, heaves in the asphalt that resemble speed bumps, etc. the 450/560 linear rate spring is beating the shit out of me and the car.
        I should mention it's a convertible and the rear springs are in the stock location, they are not true coilovers back there. I'm looking at this chart:
        Originally posted by jaywood
        Let's start with spring rates:
        Spring---------------------Front(lb/in.)-------------Rear(lb/in.)
        Stock 325i-----------------------106------------------------245
        Stock 325is----------------------118------------------------265
        Stock 325ix----------------------106------------------------308
        Stock M3-------------------------114------------------------314
        Stock M3--------------------------140------------------------250
        Dinan Sport-----------------------172------------------------300
        H&R OE Sport---------------------180------------------------380
        H&R Sport-------------------------180------------------------380
        H&R Sport (29664)---------------200------------------------285
        H&R Race-------------------------315------------------------ 570
        H&R Coilovers***----------------340------------------------380
        Eibach Pro-Kit--------------------102-------------------------277
        Eibach Race----------------------160-------------------------445
        IE SIII----------------------------315-------------------------570
        Koni Coilovers-------------------342-------------------------407
        Cosmo Coilovers----------------450-------------------------560
        Tokico----------------------------165-------------------------265
        TMS J-Stock**-------------------680------------------------1026
        Alpina(est.)---------------------~200-----------------------~350
        FK 60/60 cup kit-----------------379--------------------------379
        Vogtland Standard***--------115/197-----------------------360
        Vogtland CS***---------------137/200-----------------------400
        Vogtland--------------------------225--------------------------360
        Most of the lighter springs there are in the 1.8~2.8x range with stock being 2.2~2.7x and it doesn't close in to the 1.5x zone until we are getting into rates much higher than I want to be in.
        If I buy a coilover spring it will still be linear rate but going from 450/560 to 200/450.
        Also I've tried vogtland, they felt ok but were seriously way too low on ride height and the rear would scrape all the time. The rear felt really dippy compared to the front, so I think keeping that ratio above 1.6 is a good idea.
        Is the HR race a progressive rate spring?
        • JRKOUPE
          • Dec 2004
          • 3159
          #454
          I hear ya...
          based on your goals..forget about Hr race..not for you.
          I run Dinan on a z3 coupe..like them alot.
          this is very subjective you know...right?..depends on shock too!
          Id say mimick Dinans rate..his stuff usually works..or even Alpina......they usually do it right.
          • bacton
            • Jan 2014
            • 3
            #455
            Hey R3v members I need some help dialing in my coilovers. I purchased and installed Megan coils (essentially BC'S) on my 88 325 and seem to be having extreme wear on the inside edge of my rear tires. I've done some reading and this seems to be a common occurrence on lowered e30's but for instance in the images above, these cars don't seem to have nearly as much of a cambered rear end. I would like to increase contact patch on my tires. Any suggestions? Fyi- Havn't had the extra cash for a proper alignment, although it tracks straight.
            • Wiglaf
              • Jan 2007
              • 1513
              #456
              welcome to r3v. read up on some threads around here, nearly anything you need to know is already here.
              anyways the rear camber goes highly negative as you lower the car and can't be adjusted unless you do some mods. the only thing to do is raise the rear ride height and make sure your bushings aren't trash.
              mods to consider-
              poly bushings all around
              eccentric bushings (not popular b/c they don't do enough and go out of adjustment)
              weld-on adjustment tabs- more popular but a lot of work
              subframe raising bushings- helps a little bit, easy to do in addition to the others. it all adds up.
              • jrockbk
                • Jun 2013
                • 369
                #457
                Loving my ground control setup but does anyone else hear noises from the springs like binding when they turn at slow speeds?
                • RedReplicant
                  • Oct 2009
                  • 270
                  #458
                  Ground Control 440lb/650lb
                  SW22 MR2 Rear KYB AGX front
                  Camaro KYB Gas-A-Just rear
                  AKG Offset FCABs
                  BMW Style 5 16x8 +23 w/ 18mm 42Draft adapters effectively 16x8 +5
                  205/45/16
                  91 318is - Gone
                  16 VW GTI
                  07 Aprilia Tuono
                  • RVA_Zinno
                    • Aug 2014
                    • 49
                    #459
                    Hey guys, this might be the wrong thread for a question but I'm looking for a good pair of springs that will bring my car down a bit lower than the stock height. Low enough to lessen body roll but still high enough where as to not scrape on anything.
                    • RedReplicant
                      • Oct 2009
                      • 270
                      #460
                      Well, went GC Race plates and the difference between the stock strut mount and Race plates is right about an inch.
                      91 318is - Gone
                      16 VW GTI
                      07 Aprilia Tuono
                      • dirtbag30
                        • Apr 2013
                        • 678
                        #461
                        looks so much better, can definitely tell the difference.
                        i have no idea what i am doing with my life
                        • RedReplicant
                          • Oct 2009
                          • 270
                          #462
                          Thank you :) Definitely looks much better but goddamn, hitting the skid plate hard a few times a day.
                          91 318is - Gone
                          16 VW GTI
                          07 Aprilia Tuono
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            #463
                            yes..it looks great..but sheesh its lo for street.
                            can u tell me how your rates feel on the street?..is it really harsh?..beating you/car up?...
                            I realize its subjective...just curious.
                            car looks really good.
                            • RedReplicant
                              • Oct 2009
                              • 270
                              #464
                              It's 440/650 and feels fine on the street, to me. Little bit of bounce over wavvy sections of road, but that comes down to me being a cheap-ass with KYB AGXes.
                              91 318is - Gone
                              16 VW GTI
                              07 Aprilia Tuono
                              • JRKOUPE
                                • Dec 2004
                                • 3159
                                #465
                                Red:
                                u r correct..prolly the shocks
                                to others:
                                I was wondering if folks could chime in on what length the frt and rr springs are.....and where you are in terms of ride ht...can it go much lower/higher? A few have included this info...cool.
                                I have 6" frt and 5 " rr about to go on....
