The suspension setup/ride height thread
  • Dustin_325ix
    • Jan 2016
    • 7
    #496
    Originally posted by nomansland92
    Those will not work, you need ix specific shocks and springs for the front. Or you can use Koni race inserts in the front and cut the housings down so you can have decent ride quality still.
    Here mine with the ix grond control coils
    So there is a coilover kit for ix's? Do you mind sending me the link?
    Thank you so much!!
    1989 325iX
    • nomansland92
      • 1657
      #497
      Thank you so much!!
      It's not really a kit, go on ground controls website and they sell a spring kit in whatever weight and length you want for the ix. Then you will need shocks, bilestien and koni make direct replacement shocks for the ix but if you lower it to much it will ride like shit so that's why some people use the generic koni race inserts and shorten the strut housings to fit so you will have some suspension travel.
      IX being restored here
      Ix turbo build here
      • Dustin_325ix
        • Jan 2016
        • 7
        #498
        Awesome thank you sososos much!!!
        1989 325iX
        • Heavy927
          • Jul 2014
          • 2
          #499
          Thought on Broadway Static 500s
          Anyone have a Broadway Static set up? Thoughts? I'm looking at fitting a set of Broadway Static 500's on my '91 E30 318is, and i just wanted to get some feed back or tips on the set up. Thanks!
          • anthonymax007
            • 174
            #500
            Not sure if I posted on here or not.
            318is w/ M42
            H&R Sport (for a convertible 318is)
            KYB shocks
            Stock spring pads
            195 60 14
            fried chicken
            • DRTSRFR
              • May 2008
              • 1836
              #501
              It's not really a kit...
              GC does have an IX specific kit...
              To be clear, the only difference is spring lengths.
              Suspension tips here...
              http://www.r3vlimited.com/board/album.php?albumid=757
              • pbmig
                • Feb 2014
                • 16
                #502
                Originally posted by johnjohnsons54
                Turner J-stock suspension on 225/45/16's
                Due to the crappy roads up north, I'm moving on to some Megan coils with more appropriate rates. I'll also be able to drop the front a little more 8)
                Hey bro are you running 16x8 on ur ESMs?
                • Peelsbimmer
                  • Dec 2012
                  • 178
                  #503
                  Originally posted by crzylildude
                  Anyone running on H&R Sport Cup Kit Suspension Package?...
                  Me! :)
                  Holy shit did you even read this post before you posted?
                  http://www.r3vlimited.com/board/announcement.php?f=156
                  This thread sure sucked last night. It just plain sucked. I've seen threads suck before but this is the suckiest bunch of sucks that ever sucked.
                  • DELPHINtimecapsule
                    • Oct 2012
                    • 1468
                    #504
                    Hi r3v. I just found a great staggered set of Alpina wheels 16x7/16x8 and plan to run them on my late model 325is, which is currently at stock ride height with OEM springs and Bilstein HD. My question is how do I get it to sit exactly like this...? Spring recommends and advice appreciated.
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      #505
                      just like that huh?......lol
                      ok..here ya go:
                      easiest way is HR race springs.....or IE stg 3.......both willbeclosetothat pic..maybe not egggzact tho
                      orrrr......buy coilovers and just set it where u want it.
                        • Oct 2012
                        • 1468
                        #506
                        ok..here ya go:
                        Thanks... will the H&R set alone drop the front enough to even out the gaps like the pictured car? I'm worried about the "reverse rake" look that the stock late model has.
                        • JRKOUPE
                          • Dec 2004
                          • 3159
                          #507
                          on my car it did..........you may have to play we rear spring pads a little ...cheap , and no biggie
                          buuuuut Hr race are not comfy on bad roads.
                          spend some time here:
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            #508
                            no reverse rake here.........try to not see the frt wheel/tire combo........this is an old pic early on in her devt to track day car.
                            there are many ways to get it done.........
                            coilovers give you flexibility above all else.
                              • Oct 2012
                              • 1468
                              #509
                              It looks like the rear arch sits over the tire, while the front has a gap. Aesthetically I'd like the gaps to be even, with an even little space between the wheel arch and the tires.
                              • MrBurgundy
                                R3V Degenerate
                                • Mar 2012
                                • 5527
                                #510
                                Get coils, I have h&r race springs with with bilstein sports and I have tucked rear wheels and the front has some gap.
