I have the bimmerworld lifetime ones. I think it was like 40 bucks, been running them for a few years already, don't know how much better the 100 dollar mounts would be.
What RSMs?
I dont care too much about stiffness, I just want them to not break. My current ones are shot and make a clinking noise that is driving me crazy every time a accelerate or shift. I thought it was a bunch of other stuff for the longest while, ad the other day thought to check them. Sure enough they were pretty worn out.
So the e46 ones work and should last a good while?Comment
RSM - change for change sake or can you tell you need them
Do you experience e30 owners change the RSM while doing the shocks, or can one determine if they're needed? I'm changing the rears shocks on my '92 Cabrio (street driving only) with the Roge shocks. RSM's get changed at the same time or no? I've been reading this and other strings and seems an upgraded RSM is preferred, even if the JTD or HD OEM (thanks Aptyp). There doesn't appear to be any metal stress visible.
130k, I just bought the car so don't know if they were replaced already. What do you think?
Pics in my album: http://www.r3vlimited.com/board/album.php?albumid=680
Matt
McLean, VAComment
They look shot to me. They're like 40 bucks just replace em.
John F. Kennedy
ordered from "Parts Dept."
thanks, Harry
Ordered the e46 Cabrio RSM from "Parts Dept." - Brian at BMW Chattanooga. Is it common or suggested to install the reinforcement plate with them? Should I also plan to replace the compression bushings in the shaft protection tubes?Matt
McLean, VAComment
so what is the part number? is it:
33521092362
or
33526779670
...1991 325iC - Mauritsblau sumthin metallic blue. DEAD
1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
1991 325iC - Calypsorot Metallic
1994 540i - Granitsilber
Originally posted by scabzzzzI've had blunts cock in my mouth, but I'm not gay.Comment
- skipping the E36 generation completely -
Originally posted by StephenAlot of newer cars do nothing for meComment
Da Parts Pimp says it is 33526779670 and that checks with Real OEM for e46 325 Ci. What they don't have the part number listed for is the reinforcing plate. It is in the drawing though. DPP - Brian, said he'd chase that down and let me know (Brian.Scroggins at bmwofchattanooga.com)
I won't know if they fit until I try it, but others on this forum say they do. Why do you have two parts numbers?Matt
McLean, VAComment
Done
Installed the e46 cabrio RSMs this weekend and the Boge shocks. Easy. They bolted right up. The reinforcement plate didn't come with them though and RealOEM didn't provide a part number for them. I'll buy them separately I guess, but I see no evidence of sheet metal stress. Ride is good.
Good luck on your projects.
MattMatt
McLean, VAComment
