HELP TRW brand tie-rods
  • davem
    • Jun 2010
    • 705
    So I got some TRW tie-rods assemblies because my supplier was out of Lemforder. After I got them the Lemforders are now in stock, go figure.
    http://www.autopartsway.ca/autoparts2/index.cfm?fetch=part~ID=1991~BMW~325is~241621
    Anyways so the TRW tie-rods look a bit different than the Lemforders and the tierods that are in the pictures of both of the sources I'm using as a guide. If you look at the end that screws into the rack, the Lemforders have two deep grooves that you bend the securing plate over (little washer with a tab). The TRWs have four grooves, but they're shallow and it's difficult to imagine how to bend the securing plate. The grooves are just too damn shallow.
    What the heck should I do? Why the heck did TRW design these differently? Or did I somehow buy non-E30 tierods?
    See the pics:
    TRW
    Lemforder
  • txtorquemade
    • 1758
    I use TRW and they fit fine. Work fine. All fine.
    sigpic 1987 325is
    • JGood
      • Jan 2004
      • 7959
      I had the same problem with my Meyle's when I did my e36 rack conversion. I just bent the tabs as far as I could (which was virtually impossible, and did nothing useful). One of them came loose, on my track car, on the track. Luckily I caught it before it fell out completely. It was still threaded in 5-6 threads. Otherwise me or someone else could have been seriously hurt. I re-tightened it, and made it very tight, and it hasn't come loose since...
      That's enough motivation for me to pay the extra for Lemforders.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • McGyver
        • 4633
        how important are those washers? i just tightened them down and used locktite on them.
        • Wh33lhop
          • 11705
          That depends. How important is your ability to steer?
          paint sucks
          • McGyver
            • 4633
            meh. i guess i'll fix it properly when i put the springs in.
            • KenC
              King of Kegstands
              • 14396
              I used a chisel and just hammered the plates into the notches.
              Originally posted by Gruelius
