strut installation problem (front swaybar droplink)
  • zandi
    • Apr 2004
    • 602
    Alright, so I'm going through the strut/shock install on my car for the first time to put in bilstein sports and H&Rs...my shocks right now ride as if theres a 400 pound couple fucking in the back seat...not that they'd fit
    anyways, removed the wheel, removed the caliber, took off the tie rod, and i got to taking off the front swaybar droplink...when I try to take off the 17mm bolt, it keeps spinning and spinning, and I look to see that also the nut as it seems is spinning too...now...I would do what I did with the brake calibers and hold it down with a wrench but theres some kind of rubber around the nut so I can't get a grip on it, what can I do about this or is the bolt fucked up??
  • Jon325i
    • 6934
    Chapter 13, page 17 in the Bentleys doesn't elaborate much on the removal of this part. Don't worry though, there is an easy solution. That rubber boot you see, if you look really close to where area where the boot meets the bracket, you will see what initially appears as a round flange.....almost like a washer. If you twist the nut a partial turn and watch this area, you will see there are two flat edges. Use either a 16mm or 17mm open-end wrench and place it on this part. Then continue to unscrew the nut on the other side. It will come off.....I know, I've dealt with this too.
    Good luck.
    Jon
    Rides...
    1991 325i - sold :(
    2004 2WD Frontier King Cab
    RIP #17 Jules Bianchi
    • bimmerphile
      • 3495
      you can also place a jack under that bolt and lift enough just to put weight on it (enough that it will be immobile, not so much that it jeopardizes you under the car) and then undo the nut side.
      • Digitalwave
        is a poseur
        • 6302
        Works for me every time.
        RISING EDGE
