Just did a suspension refresh and upgraded to urethane offset bushings. Lots of squeekin going on...from previous threads I remember reading various applications of either "to" or "not to" do's and now forget which it is. Can I dab a little bit of lithium grease or something else in the bushing to quiet the CAB?
CAB lube
My AKG's continued squeaking after lubing them with some thick black brake caliper grease. Guess what finally shut them up? I got some cheap home depot wire brush, removed its handle, then fit it in my drill. Honed the inside of the bushings out just a little, then regreased, never squeaked ever again!Supatek -noun - your basic know it allComment
I use "Marine Wheel Bearing Grease", the stuff is sticky and slimy. Probably isn't the best for your bushings as you are supposed to use synthetics, but I did over 100,000 miles on a set of Energy CABS with no issue.Comment
I use ATE Brake Lube, works great.Alex 88 m5 | 91 318is | 19 Subaru Ascent
BMW Tool Rentals & Fender RollerComment
