19mm rear paired with 21mm vert front?
  • hurttech
    • 237
    Would this be too much rear bar? I'm gonna be using them with vogtland springs and kyb's. Would the 14.5mm rear be a better DD set up? Really just want an OEM+ set up. Car is an 84 e.
    Thanks
  • ÜberslowETA
    • 190
    Im also interested in this question. Im planning on going 21 from a vert in front and an IX rear but Im afraid it may not be enough in the back.
    • evilnickwong
      • Aug 2007
      • 302
      Alot of the feedback I've read on this very subforum seem to show that most people prefer having a stock rear bar or no rear bar at all. Too hard of a rear bar makes the rear end skittish/too stiff and breaks more unexpectedly.
      Personally, I'm going to be going 23/12 for my 318i. :P
      • rav320uk
        • Jun 2004
        • 1337
        Are these coilovers you're going for??
        Is the car for track use?
        If yes, then over here alot of the guys tend to loose the rear ARB as it causes oversteer on the track.
        If you have bought items from me, please leave feedback below.
        If you are a BUYER, Check My Feedback.:up:
        http://www.r3vlimited.com/board/showthread.php?t=183860
        Check out my Euro Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=215557
        • hurttech
          • 237
          Well that's my question. I know guys lose the bar when they are running stiff springs/coilovers, but I'm gonna be on Vogtland springs which arent the stiffest out there.
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            Yes, I think the 19mm rear would be overkill
            • george graves
              • 20003
              How much does engine weight up front affect the choice in bars? Would your advice change from a m42 car to a m30 car?
              Originally posted by Matt-B
                The correct sway bars are driven by the choice of springs. 22/19mm bars are a good match for springs whose rates are around that of H&R Race springs. Go stiffer or softer and you'll need different sways for handling balance.
                • hurttech
                  • 237
                  So if i were to run vogtlands, my best bet would be 21/14.5 bars?
                  • gearheadE30
                    • Jun 2007
                    • 3734
                    ^^ not necessarily, but they will certainly help. Some of ARB choice comes with your driving style, because they have a very big impact on the balance of the car. I have relatively soft GC coilovers on my car now, and I'm running a 21mm front and 14.5 rear. The balance is good, but I'd like to go stiffer on the front. IMHO, stiffer than a 14.5 in the rear just cuts down on rear traction too much, unless wherever you run doesn't have any bumps at all, hah. Likely what I will eventually di is weld M3 tabs onto the front strut housings to get the extra stiffness I want.
                    Project M42 Turbo
                    • hurttech
                      • 237
                      What about a 16mm rear bar? Didn't really know these existed untill a couple days ago.
                      • robrez
                        • Jul 2008
                        • 3376
                        I like the idea of running a 16mm rear sway bar if you're running fairly soft aftermarket spings. I just picked up 16mm Dinan rear for my vert. I'm also switching to m3 style ASB mounts for my 21mm front bar. I have Dinan springs.
                        January 2012 COTM
                        • shiboujin
                          • Feb 2006
                          • 2791
                          Real men run no real bar and 1000#+ rear springs.
                          • gearheadE30
                            • Jun 2007
                            • 3734
                            Real men can spell.
                            Project M42 Turbo
                            • shiboujin
                              • Feb 2006
                              • 2791
                              HA, you must have missed the last man meating.
