e36 M3 springs on an IX
  • enercity
    • May 2005
    • 348
    I read that someone on here is running e36 M3 springs on an IX. Does this work well? What shocks would be good to run with them?
    thanks,
    -tom
  • decay
    • 5637
    i don't have an iX, but for curiosity's sake i snaked a set of aftermarket springs intended for e36m3 off of ebay. i'll compare them to the loose e30m3 springs i have and post my findings.
    past:
    1989 325is (learner shitbox)
    1986 325e (turbo dorito)
    1991 318ic (5-lug ITB)
    1985 323i baur
    current:
      • 34847
      I'm not sure E36 springs would match up well to the ix drivetrain. they might be too stiff in the front (understeer!). but I suppose they might fit.
      as far as shocks, Bilstien HD at the minimum, Konis prefferably. there is no Bilstien Sport for the ix, and the only other option are Boges (and those won't do!).
      • decay
        • 5637
        well, for fitment, i don't know yet, but i'll post when i do.
        as far as spring rate, if you wanna go with aftermarket stuff, there are solutions out there that probably won't cause understeer. the springs i ordered are f168/r436 :twisted:
        past:
        1985 323i baur
        current:
        • Digitalwave
          is a poseur
          • 6302
          E36 springs do not fit E30 struts.
          RISING EDGE
          • decay
            • 5637
            Quik325iX says otherwise here:
            but we'll see later this week when they show up. if they don't fit, i got them cheap through a dutch auction, so i can pawn them off on some DTM/BF member and probably only lose $20 or so.
            past:
            1985 323i baur
            current:
            • Digitalwave
              is a poseur
              • 6302
              Have you ever worked on an E36? Or seen E36 springs?
              RISING EDGE
              • decay
                • 5637
                no, and my intent is not to argue with you.
                however, if you look up upper and lower spring pads on realoem.com, you'll find that the numbers match for pads for e30 325i and e36m3, front and rear.
                i think that gives me pretty good odds. if you have information that says otherwise, i'm listening.
                like i said, i have a set of e30m3 springs that i never bothered to install, so it's not like it's going to cost me anything past purchase price to compare the two. and if it doesn't work out, oh well, back to the fleabay they go. it's worth the ~$20 it'll cost me to satisfy my own curiosity.
                past:
                1985 323i baur
                current:
                • 2002man
                  • May 2005
                  • 6
                  update? :P
                  • decay
                    • 5637
                    tein s-tech for e36m3 arrived last night.
                    front on the aftermarket springs i got is a bit shorter, but they're supposed to have a bit of rake to them.
                    other than that, the contact surfaces are the same diameter, front and rear, top and bottom.
                    if the aftermarket springs i got weren't considerably thicker, and green, i could have gotten them confused with the e30m3 stuff.
                    past:
                    1985 323i baur
                    current:
                      • 34847
                      how much shorter are they than ix springs?
                      • decay
                        • 5637
                        no idea, i only have the e30m3 springs to compare to, sorry.
                        sounds like the dude who said he had stock e36m3 springs on his iX wasn't blowing smoke, though.
                        past:
                        1985 323i baur
                        current:
                          • 34847
                          well, here's the thing.. they might fit, but I'm not sure they would be a good setup. they might also be far too short (hope you don't mind replacing CV boots often).
                          • decay
                            • 5637
                            hopefully Quik-325iX posts some thoughts of his- as i'm an iS owner, front CV's aren't one of my worries.
                            past:
                            1985 323i baur
                            current:
                            • enercity
                              • May 2005
                              • 348
                              Quik325ix said they lower it about 1.5"..which is less than the B&G springs made for the IX.
