Cabrio Suspension Differences
  • LuckyHenriksen
    • Jun 2010
    • 4244
    Is there any difference in the front strut housings and rear sub frame between Cabrios and Sedan/Coupes? Can they be swapped back and forth without issue?
    Bahama Beige E23 Project
    Bluebird Bus Conversion
    New Oregon Trail
  • F34R
    sLaughter
    • 12376
    I think the tubes are bigger on the housings for the cabby. The Konis were back ordered for the size used in the vert. So I order Bilstein sports and swapped the housings from a 88 sedan to the vert. Worked perfect no issues. This was for a coilover application.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • E30m42cab
      • Aug 2009
      • 190
      No difference.
      • Naplm00
        • Nov 2008
        • 1573
        This is only true if the car was a 318 otherwise they all the same.
        88 325ic ~~~> Rusty and ugly
        85 E ~~~> RIP
        • downernsp
          • Mar 2008
          • 1932
          Early vs. late only difference correct me if I am wrong. Oh unless IX of course.
          • LuckyHenriksen
            • Jun 2010
            • 4244
            Ok thanks very much. My cab and my parts car are the same year/model so it should all work out fine
            New Oregon Trail
            • Cabriolet
              • 9620
              something not mentioned is that cabby's sit very low in the back. like 1/4-1/2 lower than a hard top. idk if it geometry or the weight but the backs are lower.
              Much wow
              I hate 4 doors
              • LuckyHenriksen
                • Jun 2010
                • 4244
                Its supposedly all the extra weight
                New Oregon Trail
                • Violet88
                  • Jun 2010
                  • 435
                  Yea for real, it's something cuz my cab sits lower in the back too
                  '88 325i cabbie royal blau
                  '91 325i cabbie calypso rot
                  '92 318i cabbie laguna green
                  ~I like all my b!tches topless ;-)~
                    • 34844
                    it's an illusion, cabbies have lower rear arches like late models.
                    • F34R
                      sLaughter
                      • 12376
                      I really did not know, I just called a few BMW shops and they said it takes a larger strut. I never checked when I did the swap. I am going to use those for my track build. So I will let you know in the spring one way or another.
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                      • Violet88
                        • Jun 2010
                        • 435
                        ooohhhh I see!
                        • e30rapidic
                          • 2167
                          front swaybars are a little bit thicker and rear springs have a higher rate for the extra weight
                          '87 325ic, powered by S50.
                          • McGyver
                            • 4637
                            i really dont know if their is a difference, but i have had coupe H&R Race and Billy Sports on my vert for a year now with no problems.
                            • DavidV
                              • Jun 2004
                              • 411
                              The struts themselves are reinforced:
                              http://www.realoem.com/bmw/showparts...48&hg=41&fg=10
                              -- DavidV :D
                              My Book: Car Hacks & Mods for Dummies
