UUC VS Susp. Tec. Sway Bars
  • TimR
    • Mar 2008
    • 549
    http://store.nexternal.com/shared/St...t=products.asp UUC bars http://www.jegs.comSuspension Techniques 52010 - Suspension Techniques E30 Bars $375 free shipping low price but comparing these sets, the UUC picture has additional rear bar upper( brackets) and lower( triangle) supports and 4 round parts, any idea what these are?? UUC looks like the best deal, anyone got this UUC set on a car??
  • Van Westervelt
    • 9365
    Neither of those links work, but I am assuming you are talking about the end links. Instead of fixed stock rubber ones, they replace them with spherical bearing adjustable links.
    Instead of the upper pics, you get the lower.
    • TimR
      • Mar 2008
      • 549
      No, the UUC set have the additional suports to add to the trailing arm and the renforcement brackets to bolt the bar to the frame, look close at the additional parts in the picture of the $440 set, link worked for UUC, you have to go find the ST bars on Jegs http://store.nexternal.com/shared/St...13&CS=uuc&All= when this was posted the UUc set was $415 ST Jegs http://www.jegs.com/i/Suspension+Tec...52010/10002/-1
      • JGood
        • Jan 2004
        • 7959
        Yes, the UUC kit is the way to go. It has very nice reinforcements and Aurora end links, very high quality stuff. It comes with 2 bars, all 4 bushings and bushing clamps, 4 end links, the triangle rear reinforcements tabs, the upper 90 degree brackets, the front sub frame reinforcements, hardware, and some lube. Basically everything you'd possibly need.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • hoveringuy
          • Dec 2005
          • 2750
          I hate the way my rear ST bar seems to be bent just *slightly* too short, the bushing is a b!tch to install.
