Suspension Setup.....
  • SLEEPERracer
    • Oct 2004
    • 215
    I have a 1985 325e with H&R OE sport springs (1" drop) with tokico gas shocks. Im looking for a lower drop or some way to stiffen up the suspension so there is non or less body roll. Only supsensions i see most people running is Ground control coilovers. I know there is also AP sporttuning, Racing dynamic springs and KW suspension (also others) out there. Im looking more towards coilover suspension and some are over 1g which i know is best but i've looked around and price ranges for ground control coilovers are near $400. I also know you could add strut bars to tighten the turning ability of the car. If you guys can give me some advise on which route to go with my suspension id appriciate it! where i can find these suspensions(websites) with pictures and prices. thanks in advance!!
  • Mystikal
    Wheel Fitment Expert
    • 9602
    For street use (and even occasional track use), I'd recommend IE Stage 3 springs over my Ground Controls, paired with Koni SA dampers. They ride significantly better, and still provide great roll control. Add a Sparco front strut bar for better turn-in.
    • SLEEPERracer
      • Oct 2004
      • 215
      is this the IE stage 3 springs??
      https://secure7.nexternal.com/shared...p;CategoryID=3
      also is this a good place to buy from...do you know any where else?? and where can i find the sparco strut and Koni SA dampers? thanks!!
      • Mystikal
        • 9602
        Yeah, that's IE's site.
        IE Stage 3 springs: www.bmw2002.com
        Koni SA dampers: www.shox.com
        Sparco brace (the $109 one): www.evosport.com
        • SLEEPERracer
          • Oct 2004
          • 215
          alright, thanks for the help!
          • SLEEPERracer
            • Oct 2004
            • 215
            the $109 Sparco Front Strut Bar will fit my '85 325e, cause it says E30 M3?? just making sure..thanks again!!
            • Mystikal
              • 9602
              Yeah it fits fine, you just have to get creative sometimes as the chassis' sag over time. Search for more info anwyays.
              • SLEEPERracer
                • Oct 2004
                • 215
                thanks again for all your help!!
                • Bavarian3
                  • 1230
                  *Strutbars r e a l l y don't help turn in*..... toe/caster/camber does....
                  thats if you want to get technical....
                  Why Koni SA shocks?.....
                  • hamann318is
                    • 3382
                    The sole reason I got the Konis was because I wanted to go from full stiff to full soft. I've also read that if you can tune the shock right, they are much better matched to the IE 3s.
                    With the full soft on the Konis, I had a very hard time telling the difference from stock.
                    The BMW 318 is back. With a vengeance.
                    • Bavarian3
                      • 1230
                      Well yes.. if you tune anyshock (revalved and to spec of the springs) then it is much better than putting a set of a springs with b shocks to get a c performance.... but then you have to factor in spending money and how much you want....
                      I was just questioning why choose Koni... only because you can click a switch to go from full soft to full stiff? Even that design is a bit off, what if you need something that is not full stiff or not full soft?
                      • Mystikal
                        • 9602
                        Technically they don't, but on our sagging chassis' it's pretty surprising just how much that bar (and the straightening you need to do to get it on in the first place) does for the dynamics. You're right though, I shouldn't say turn-in.
                        Konis because they offer better rebound control and offer more travel, plus the softer compression leads to better ride quality. I honestly have never really seen a good reason to get Bilsteins instead.
                          • 34836
                          konis are adjustable for more than "full stiff" and "full soft". you can basically set them at an infinite number of points inbetween.. and there is no "switch" you can click, either.
                          the thing I have found with konis is once you have adjusted them to where you like them, you don't change them a lot. I've adjusted my rears twice since I got them and my fronts once.
                          • hamann318is
                            • 3382
                            I've changed the fronts and rears 2 times. I did full stiff all round, and now I'm at 3/4 front and about 5/8 rear. I haven't touched it since then.
                            • SLEEPERracer
                              • Oct 2004
                              • 215
                              sorry for bringing this up again but which is the koni SA dampers.....just want to make sure i dont order the wrong thing.
                              thanks!
